Introduction: Paperclip Rose Dangle Earring - Made at TechShop!
You'll need
1 RED Paperclip
1 GREEN Paperclip
Pliers
Super Glue
Step 1: Straighten Out the Clips
Refer to title
Step 2: Cut the Green Paperclip
It should be about 3 1/2 in when straightened out, cut it at about 1 1/2 and curve the longer piece.
Step 3: Start Wrapping the Red Paperclip Around Needlenose Pliers
Start from the tip and wrap twice
The plastic will most likely strip away, but it'll be okay as long as it's not too much.
Step 4: Wrap the Bud Around the Stem
Wrap it tight around the Stem at least twice, and then start molding the shape.
Use fingers when necessary and don't get too carried away!
Use superglue to secure the connection.
Step 5: Make the Leaf
Use the remaining Green piece and curve it to make a loop around the stem, then join it together at the ends to complete the Leaf.
Step 6: Shape It!
Shape the earring to your preference.
I like it as more of a closed hoop, but females can wear them longer if they choose.
Adjust sizes and experiment as you see fit.
Paperclip Earrings!
