Paperclip Buckle Belt
192
Published
Introduction: Paperclip Buckle Belt
This is a super easy belt to make that does not require buckles from craft stores or old belts. I wanted to restrict my materials to whatever I could find at Walmart. The paperclips did a surprisingly good job of keeping the belt tight around my waist.
Materials:
2 large paperclips
old t-shirt
pliers
Time: 2 hr
Step 1: Make the D Rings
Straighten out the two paperclips, then use the pliers to shape them into the shape of a D. Make sure to wrap intertwine the paperclip ends on the flat side of the D ring.
Step 2: Cut Up the T-shirt
Cut the t-shirt from top to bottom. Make the strips even in length and fairly wide because they will be thinned out later afterwards.
Step 3: Making the Belt Strands
Stretch and curl 5 t-shirt strips. If the strips cannot be wrapped around your waist at least 6 inch left over, tie the strand with another strand.
Step 4: Tie the Strands on the Two D Rings
Cut off any excess.
Step 5: Weaving
Start by taking the last left strand and pull it over and under the neighboring 2 strands. Repeat with the last right strand. Repeat this with the last left strand then last right strand until the belt is complete.
Step 6: Tie Up the Loose Ends
Cut off the fabric ends afterwards.
Step 7: How to Use
Pull the belt end through two D rings, then pull it over only one of the rings.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
