Papercraft with Aluminium Cans
 by duk242
Featured
I wanted to see if papercrafting was possible using aluminium cans (ie. Coke cans), I did a bit of a google around and there doesn't seem to be a lot of information on the subject, so I figured I'd do some research and try a few techniques out to see what I could come up with.  I've split this into sections to make it a little easier to read.
If you've never made anything out of papercraft before, I suggest you look elsewhere Papercraft Museum and make something out of paper, it takes a significant amount of more effort (and time) to work with aluminium.
Step 1: Flattening Aluminium Cans
First up, I used a knife to cut the top and bottom off the can (you can use scissors, but you'll need to use a knife to get a start to it) and then using scissors to chop the cans into a piece I can flatten. After you've cut them into sheets like that, neaten the edges by using a pair of scissors to cut them straight and make sure there's no little sharp bits.
The method for flattening the cans that I've found works best is to use a sandwich maker (an old one, don't ruin your good sandwich maker!!). Before turning it on, lay down a piece of baking paper on the bottom, put about 4 cans in, then add another layer of baking paper on the top (this should help prevent at least a little bit of damage to the sandwich maker).
Hold the cans down flat as you close the lid, once you've done that, turn the sandwich maker on.
I haven't fully experimented with getting the best efficiency here, but I left it on for 10 minutes with 4 cans in there, then turned it off and let it cool before I opened it.
Taadaa! Flat cans!
Other methods I have tried are:
* Ironing (Does nothing)
* Ironing and bending at the same time. This method works, but you end up with your piece looking a little bit bent as it's hard to get it as flat as you would in a sandwich maker.
* Clamping it between 2 pieces of wood. This does absolutely nothing, if you leave it for a day or a week, they bend right back to their natural shape.
It seems like heat is very important in getting these things to stay flat.
Step 2: Cutting the Sheets
I printed my design out on paper first, cut the paper version out then used it to trace onto the sheet. You may end up with pieces that're bigger than the can, so you'll have to deal with this by splitting it into 2 pieces.
Also, because the cans are way thicker than paper, you'll end up with parts that will fall short because the thickness of the paper messes it up. I just dealt with it as I went and it may have resulted in a less than perfect final product, the design would probably have to be altered to give a bit of room in some corners to account for the extra thickness.
Using a knife is practically useless, you just can't drag a knife through aluminium like you can through paper.
Scissors on the other hand are brilliant, it's just like cutting through paper. The only issue is the end of the scissors can cause the aluminium to bend a bit. To counter this, I use a knife to piece the corners, then use the scissors to cut up to them. It's not perfect but does the trick nicely.
You should also score the pieces using whatever you normally use to score, I use a thing that's a bit like a needle on the end of a knife handle.
Folding is pretty simple, just do as you normally do. Be careful about bending too much though, as the metal will weaken the more you bend it!
Step 3: Gluing
This part is rather difficult, I tried a whole bunch of glues to work out how to get it to stick properly, I ended up settling on Contact Cement. (Contact Cement is the sort that you apply to both surfaces, let sit for ~20minutes then push them together).
This part is going to take the majority of your time, I suggest you glue 1-2 pieces at a time, put the contact cement on them, let them sit the full 20 minutes, then push together (hold for ~10 seconds or so to make sure it's solid) before moving onto gluing 2 more pieces. Get a movie out, play some games... It'll take a while.
The contact cement wasn't the greatest however, as if the metal is trying to flex against the glue, it'll pull itself apart unless you sit there holding it for at least 30 seconds, even then it doesn't feel as strong as one would hope.
I didn't end up trying Epoxy however, so that would be a good thing to experiment with.
Other glues I tried:
* Aleene's Original Tacky Glue (the metal surface was too shiny for the glue to stick once it dried). This is the glue of Papercrafting gods that I had to import from the US to Australia. It's very similar to PVA/Wood Glue, just slightly tackier making it awesome for papercraft. Just not for... Aluminiumcraft :P
* "Hobby Cement" - Same deal as the Tacky Glue above
* Bostik Multi Bond - Same deal as above, it just can't stick to the metal as well as it should.
Step 4: Finished!
And here's my end result! Would I do it again? Nope, it took me about 3 days to get the whole thing done when the paper version took closer to a couple hours....
The design I got from: Tenpepakura Translated
And thanks to: Build Totodile  for showing me where to get it :D
duk242 (author) says: Jul 11, 2012. 7:54 PM
For those of you thinking to try Epoxy glue, this is what happened:
1. Mixed the Epoxy resin stuff with the hardener
2. Stuck the pieces together and held them for 5 minutes.
3. Let go of the pieces.
4. Observed as the aluminium flexed itself back to how it was before being glued (apart!)
5. Stuck it back together and used a weight to hold them together
6. Let it sit overnight
7. Tested the glue strength, seems to be holding well...
8. Flexed the metal
9. Glue breaks off, metal falls away. Sadness ensues.
Basically: Epoxy works if your metal isn't going to bend at all.
ejones182 says: Apr 6, 2013. 8:36 PM
Thanks for sharing your findings! I'm working with aluminum right now too and found this information very valuable.
For another adhesive option, try Glue Dots...you can find them in the scrapbooking section of a craft store. They're super sticky for an instant bond. You can also find Mini Glue Dots for smaller work.
For others on this thread...I finally found a flat sandwich maker - it's a Cuisinart panini press/griddle with removable plates...the plates you remove have grooves, but once you remove them, you're left with two flat surfaces :)
Smalfrii says: Jan 26, 2013. 12:56 PM
ah. found it!
Smalfrii says: Jan 26, 2013. 12:54 PM
what is the template called?
cowsclimbtrees says: Aug 14, 2012. 6:49 AM
You could try soldering the aluminium pieces together. then you only have to wait 10 sec for it to cool.
duk242 (author) in reply to cowsclimbtreesAug 14, 2012. 3:03 PM
I considered trying that.. then my 3D Printer arrived so I put it on the backburner for a while... I might give it a shot some time though (I'll post here if I do)
MaskMarvl in reply to duk242Nov 28, 2012. 8:10 AM
If by solder you're thinking of using a regular soldering iron and solder used with electonic circuits, make sure you buy solder for Aluminum. Regular solder won't work... it'll slide right off. (Nice work by the way) :)
Cheeseduck says: Jul 15, 2012. 12:19 PM
One thing to try is using sandpaper to roughen up the parts you want to glue together.
duk242 (author) in reply to CheeseduckJul 15, 2012. 3:09 PM
I sort of tried that, I used my scoring tool thing to scratch up the surface a bit, it helped a little bit but not as much as I had hoped...
Thrasym in reply to duk242Oct 10, 2012. 6:54 AM
Aluminum is difficult to work with. You'd think it was the easiest stuff on the planet to work with, since it's used in so many ways, but it isn't. It actually is really hard to glue or paint, because it forms a film fairly fast on the surface that must be removed right before you glue or paint it. Aside from that, cans have a plastic coating which glue doesn't stick to. Scratching it with pointy tip isn't going to do anything, considering the "scratched" surface is such a small fraction. You really need to physically remove the impurities with fine sandpaper or chemically with harsh cleansers.
Anyway, if you prepare it properly, good epoxy glues will hold well. Of course, you'd want to form the pieces first, so they don't want to pop apart, especially if the glue surface is going to be small, but that can be overcome with reinforcements possibly (depending on design I guess).
End result of your instructable came out great. I'm going to have to give it a try.
slylee says: Jul 15, 2012. 11:56 AM
this is awesome. great instructable.
bconway1 says: Jul 15, 2012. 12:10 AM
Just a little tip, if you sand the pieces you were to glue together and clean them with acetone than water, it might stick better.
l8nite says: Jul 14, 2012. 9:16 PM
the result is really cool, thank you for sharing all the gluing information you learned as well
sdfgeoff says: Jul 11, 2012. 6:11 PM
Lucky you, my sandwich maker has a pattern.....
duk242 (author) in reply to sdfgeoffJul 11, 2012. 6:28 PM
Over the years we've gained 4 sandwich makers, I was glad to put one of the old ones to use :P
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
