Here are my DIY tips for creating the papier mache planets. This is a great craft to do with your kids. Keep in mind that this is a labor-intensive DIY project but so much fun!
Step 1: Gather Balloons
I gathered an assortment of round balloons
Step 2: Create Papier Mache mixture
I then created my papier mache mixture by mixing flour and water. This is your "glue". Should be the consistency of pancake batter...you could probably add some eggs and milk, hmm, and some chocolate chips...ok...I digress. You get the point.
Step 3: Start applying
I applied three layers of strips to each balloon, allowing each layer to dry in between. You don't want to be so neat and smooth with the layering. Remember, planets are textured, I think, either way, they're more interesting that way.
Step 4: Drying Process
On a damp day, placing the planets in front of  the oven door helped speed up the drying process. Temperature around 200°
The balloons will shrivel up...and die, I mean dry. No point in trying to remove them.
Step 5: Base Coat
Once dry, I painted each planet with a coat of white primer before applying the color. Then let them dry again. Resting the planets on flower pots helps keep them stable.
Step 6: Start Painting!
I use acrylic paints. The colors are easy to mix and they clean up easily with water.
This image shows the first layer of color. Let each dry before your second coat. At this point, I added hooks made out of a piece of wire. Almost like an upside down "T"  with a loop. insert into the hollow planet so the top of the "T" sits within each side of the hole.
Step 7: I'm ready for my closeup
A closeup of Neptune and Venus.
With two coats of base color, sponge on a second darker or lighter color to bring out the texture. This works best when the planet is not fully dry. Have fun, you can't really make any mistakes here.
Spray a gloss coat on to give the planets some shine and protection.
okudaisi says: Aug 30, 2012. 8:35 AM
great idea!
Facci Designs (author) says: Sep 5, 2012. 1:28 PM
thank you!! Hope you make them too!
wynelle says: Sep 18, 2010. 10:19 AM
Awesome job ... one question though ...
What did you use for the rings of Saturn? How did you attach them?
Facci Designs (author) says: Sep 18, 2010. 4:23 PM
thanks. I cut the ring out of foam core and covered it in some sparkly paper. Since there was a hook on top of the planet, I strung fish line through some holes in the ring and connected it to the top of the hook. I wanted to look like it was floating.
scoochmaroo says: Sep 16, 2010. 9:24 AM
Beautiful! I bet rich people would pay lots of money to have these as objets d'art!
Facci Designs (author) says: Sep 16, 2010. 1:00 PM
wow, you think so? Maybe someone rich will see these and want me to make more! :)
scoochmaroo says: Sep 16, 2010. 3:24 PM
Try charging a ton of money for them on etsy and see what happens!
cokecola says: Sep 16, 2010. 8:14 AM
Excellent paint job! They look like gemstones.
Facci Designs (author) says: Sep 16, 2010. 12:59 PM
gemstones shining in the sky! thx
depotdevoid says: Sep 15, 2010. 12:44 PM
Those are awesome, quite eye catching!
Facci Designs (author) says: Sep 15, 2010. 1:16 PM
Why, thank you! Aren't they Out of This World? :)
Facci Designs (author) says: Sep 15, 2010. 9:02 AM
thanks.
They were for a client who wanted them for her son's "Space themed" Party.
Culturespy says: Sep 15, 2010. 8:42 AM
Really nice job on these! Will they be display models or are they part of another project?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
