Parabolic Solar Tracker in Carton (DIY Arduino)
2,005
35
Published
Introduction: Parabolic Solar Tracker in Carton (DIY Arduino)
About: Tech, DIY and Arduino Realisation If you liked it , come check our sites Website :http://technofabrique.wixsite.com/techno-fabrik Google +:https://plus.google.com/109229784299061111421
[FRENCH]
L'objectif est de créer un tracker solaire parabolique autonome permettant de suivre le soleil, et donc d'obtenir le meilleur ensoleillement possible.
[ENGLISH]
The goal of this project is to create a parabolic solar tracker that is going to follow the sun during the day , to get the maximum of light .
Step 1: The Material You Need !
(x1) --- Arduino Uno
(x1) --- Stepper Motor Nema 17 ( +12V alimentation, Torque: 44 N.cm = 4.5kg.cm)
(x1) --- Driver to control the Nema 17 : A4988
(x1) --- Capacitor 47 uF
(x1) --- Stepper Motor 24BYJ48 ( +5V alimentation, Torque : 39mN.m = 350g.cm )
(x1) --- Driver to control the 24BYJ48 : ULN2003
(x3) --- photorésistor
(x3) --- 1kOhms résistor
(x1) --- Alimentation for the Stepper motor Nema 17 : +12V
(x1) --- Alimentation for the Stepper motor 24BYJ48 and the arduino : +9V for me , then +5V to the stepper motor
(x) --- Carton
(x) --- Glue pistol
(x) --- Aluminum
(x) --- Rope
Step 2: How to Build the Parabola
The first step is to create the parabola.
In order to do this, we started by cutting 12 parallelogram of 16x26x10 (cm), and 12 other (10x17x2.5 cm).
We cover each parallelogram with paper aluminum and we stick them together to create the parabola.
Our parabola have a focus close to the base of the parabola, so maybe with 11 parallelogram, you can get a focus higher.
Step 3: The Solar Tracker Device
We reproducted a solar tracker made with 3 photoresistor. Each photoresistor is connected with a resistor of 1Kohm, and send to the analogic input of the arduino.
We can know if our parabola is well positioned or not, by checking our inputs.
Example : The picture
In the picture, we see that the photoresistor n°0 receive lesss light than the others photoresistor.
That is traducted in the arduino by a higher value in the input n°0 . So we know that we have to turn the motor used to the rotation of the parabola to be in front of the sun.
Step 4: Rotation and Inclination
To inclinate the parabola, we used the 24BYJ48 Stepper motor and his driver ULN2003.
We just wrap the rope in the motor to make the parabola inclinate.
To make the parabola rotate, we glued a wheel at the base of the parabola, wich is pulled by the Nema 17 ( Stepper motor).
We only need 1 sense of rotation, because we just want to follow the sun.
That mean that every day, we have to put the parabola in the right way, but we are good with this.
Step 5: The Setup
(FRENCH)
ETAPE 1: La parabole
La parabole a été réalisée à partir de 2 x 12 parallélogrammes fait de carton et recouvert de papier aluminium. Cette parabole est ensuite traversée par une barre permettant d'incliner ou non la parabole grâce au moteur pas-à-pas 24BYJ48. Au bout de la barre, on a fixé notre module composé de 3 photorésistances . ( voir la page du
ETAPE 2 : Le moteur pas à pas 24BYJ48
Nous avons connecté le moteur bipolaire pas à pas 24BYJ48 à son driver associé contenant le circuit ULN2003. Il suffit de connecter les inputs INx (x = 1,2,3,4) aux sorties digitales de l'arduino. On alimentera le driver en +5V. Pour coder, nous utiliserons la bibliothèque Stepper.h , ce qui nous permet de commander facilement le moteur en lui donnant la vitesse : nom.setSpeed(vitesse), ainsi que le pas désiré : nom.step(+ou- pas)
ETAPE 3 : La rotation de la parabole
Pour faire tourner la parabole, nous avons mis celle-ci sur une base tournante. Le moteur pas-à-pas NEMA 17 ainsi que son driver A4988 permet de faire tourner la parabole dans un sens. Remarque : Nous n'avons besoin de faire tourner la parabole dans un seul sens pour ce projet, car la parabole doit suivre le soleil. Il faut par contre replacer la parabole tout les matins.
ETAPE 4 : Le moteur pas-à-pas Nema 17
sous-étape 1 : Liaison Arduino - A4988 On connecte l'alimentation de la partie commmande au module A4988. La broche 3 est connectée au step du driver: on pourra alors moduler la vitesse de rotation du moteur. La broche 4 est connectée au dir du driver: cela nous permet de choisir le sens de rotation en mettant ce pin à HIGH ou LOW. sous-étape 2 : Alimentation des moteurs Les moteurs sont alimentés en 12 V (nous avons utilisé une alimentation d'ordinateur). On ajoute un condensateur de découplage de 47uF pour sécuriser le driver de possible pique de courant causé par le moteur.
Step 6: The Code You Need to Write
// 07/2017 - Programme C - Tracker solaire Parabolique -  Carte Arduino ( UNO )// Ce programme a pour objectif de :  //                                     -  Traiter les informations apportés par les photorésistances //                                     -  Gérer la rotation et l'inclinaison du module pour suivre une source lumineuse // Programme réalisé par Techno_Fabrik
//********************BIBLIOTHEQUES****************************  // bibliothèque permettant d'utiliser les commandes pour le moteur pas-à-pas 24BYJ48 et son driver facilement  #include   //********************DECLARATIONS****************************  //Le moteur (fils 1 2 3 4) est branché sur les sorties 8 9 10 11 de l'Arduino (et sur GND, +V) Stepper small_stepper(STEPS, 8, 10, 9, 11);     // Sens horaire    int A4988_pas = 3; // nema 17 definir la vitesse int A4988_direction = 4; // nema 17 definir la direction float photo_r_0,photo_r_1,photo_r_2; // valeur des photorésisances
//*************************INITIALISATION **********************
void setup() {
pinMode(A4988_pas,OUTPUT);
pinMode(A4988_direction,OUTPUT);
Serial.begin(9600);
//*************************************** BOUCLE ***************************
void loop() {
photo_r_0=analogRead(A0); // entrée analogique 8 bits = 1024 valeurs = 0 à 5V
photo_r_1=analogRead(A1);
photo_r_2=analogRead(A2);
if ( photo_r_0
photo_r_1+3)
   digitalWrite(A4988_direction,LOW);
  for(int x = 0; x < 1; x++)
    digitalWrite(A4988_pas,HIGH);
    delay(5);
    digitalWrite(A4988_pas,LOW);
    delay(5);
if (photo_r_2>photo_r_1+3) // tourner la parabole en avant
small_stepper.setSpeed(40); // + Speed = - Couple  ,
small_stepper.step(10);
else if (photo_r_2
Step 7: It's Finish ! See the VIDEO
Thanks you very much !
If you liked this post, please come check our other presentation on Instructables !
If you want to visit our website : http://bit.ly/2viP7No
To follow us on Instructables: http://bit.ly/2vYQwL7
Hope you appreciated ...
Solar Contest 2017
Runner Up in the
Solar Contest 2017
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    2 Comments
    You should enter this in the ongoing solar contest. This was a very well done project. I was looking for something exactly like this to try this winter for a solar project I'm starting to work on. I plan on using worm gears and high torque motors to move a 4 panel solar rack I'm going to construct. Love it.
    Hi !
    Thanks you very much for this comment :)
    Yeah i added this project in the solar contest ! Hope you are going to succeed with your future project .
    Best regards
