Parabolic String Lamp
14,427
402
16
Published
Introduction: Parabolic String Lamp
About: I'm an Instructables success story! After relying on the site to DIY my way through art school, I was able to join the Instructables Design Studio in 2012. It's the best! Whe...
This Parabolic String lamp is made out of laser cut wood, yarn, and a pendant light kit.
I was thumbing through some vintage interior design magazines and found all these kind of cool examples of Parabolic String Art.
I examined it closely and figured out how the illusions of curves appeared in the string art. I was curious if the same principle could be applied to a curved dimensional object. I tinkered with a few different designs, and materials - the lamp featured in this Instructable was actually the fifth iteration in my design process.
Step 1: Laser Cutting
I designed the lamp, and it's feet in Illustrator. It was a little tricky to figure out a design for the notches along the wheel, I tried teeth vs. holes vs. notches vs. kerf cuts.
It turns out I needed a notched hole for the best way to catch the string. I used a laser cutter to make my cuts into 1/4" plywood, but I think I could achieve the same effect with a band saw and a drill press. (And a lot more time, this cut took 5 minutes on the laser)
I have attached my files to this step -let me know if you need a different file format.
Step 2: Assemble the Lamp.
I used this Pendant Lamp Kit from Ikea. It turns out these aren't sold in California any more, but we had one lying around.
I designed the hole large enough to fit the socket, but small enough to grab the plywood with the coupler in the lamp kit.
Step 3: Fins and Bulb
I added all of the fins to the lamp, one at a time, making sure to connect it all the way into the notches.
After they were all installed, I screwed in the light bulb. Pretty easy step.
Step 4: The String
By far the longest part of the process, was weaving the skein of yarn into the lamp.
I was able to start the weaving with just a single knot that wouldn't slip through the notch in the fin.
I used cheap red craft yarn and wove it up and down each fin, slowly working my way around, over and over and over and over again.
I was able to end with a single knot in the notch, and cutting the extra off. I pretty much used the whole skein for this design.
Did I iterate that this took a long time? It did.
Step 5: Give It Legs
If you want, you can give it legs, they just attach with a tight tolerance in the notch.
Step 6: It Hangs!
I like it better as a hanging lamp. I think it looks more beautiful suspended from the ceiling - it allows the design to sing a bit more.
I will award a 3 Month Pro membership to the first five people that make this project, let me know using the "I MADE IT" button.
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    16 Comments
    would you send me the DXF file please?
    How do you change the light bulb if it burns out?
    Could you give me the dimensions? I don't have a lazer cutting machine. So I can use the dimensions.
    the dimensions are in the .pdf file.
    I re-checked the pdf.. I dint find any dimensions. Pls help!
    i will make it as i had two laser cutting machines and i will post my creations
    thanks
    this is very good site
    Nice work. However I don't have access to a laser cutter. I do however have a scroll saw. But your PDF does not print in a 1 to 1 template. That would be very useful. Thanks
    I have updated the files and added a slightly larger model as well.
    this is absolutely gorgeous!! i totally love it!!
    It looks so beautiful, I love it!! :)
    Beautifulll!!!!
