loading
Step 2: Step 2: Layout
Step 2: Layout
Taking the calculations from Step 1 you will want to lay out the curve of the dish on a flat surface. Accuracy is important but you can be off slightly and still have an operational dish.
First measure your width (diameter) and find the center point. Now go to Parabola note a point (X, Y) on one side of the dish. Then measure the bottom edge from the center out to one side. Then measure the height up from that point. To assure you are not off to an angle use a T square if you do not have a T Square you can measure the depth again from the center of the dish Up and then from there the distance to the side. Repeat this process on the opposite side. Then do it again 3-4 more times at different points on each side marking each point with a dot or X. Connect the dots and you should end up with a curve like the one in Parabola.
<p>Great instructable. I will try a smaller version for my nrf24 transmitter.</p>
it really nice...Can we use umbrella and wrap it with alluminium foil?...Thanks..
it may work the key is the arc
Nice work! <br> <br>I do a subtle clarification: your parable don't boosts the wifi, it only redirect it toward a desired point. The difference begins to be important if you have two receptors (in example two notebooks) at opposite or angled directions.
Thanks for the clarification. I don't believe I used the word &quot;Boost&quot; You are correct as it has no power it does no boosting. The way a Parabolic works is that it reflects the signal from a larger surface area than that of the antenna alone. Then concentrates it at the focal point. This dish as crude as it may look gives me ~13db gain recieving from the same router it was before.<br><br>I added a clarification to the Intro<br><br>Thanks
About This Instructable
36,959views
27favorites
License:
More by thekraftyrhino:Parabolic Wi-Fi Dish
Add instructable to:
