Introduction: Paracord Bracelet Instructions
Paracord Bracelet Instructions with the cobra Paracord braid. The Paracord Supplies you will need: about 12 feet of 550 paracord, a Paracord buckle. You can get a Plastic or Metal Paracord Buckle, Metal paracord buckles can be uncomfortable to wear because of the weight on small wrists. You will also need these other Paracord tools, scissors, a lighter, and optional a Paracord needle. See all the Paracord Bracelet Patterns.
Step 1: Paracord Bracelet Instructions - Step 1
Attach the Paracord to the to the buckles like in the picture below. Then measure it on your wrist to make sure your Parachute cord bracelet will be the right size.
Step 2: Paracord Bracelet Instructions - Step 2
Bring the first piece of Paracord across the center of the bracelet. Note, This will be the center color of the bracelet, and continue the Paracord Bracelet Instructions.
Step 3: Paracord Bracelet Instructions - Step 3
Now take the other piece of paracord, and bring it over the top of the first piece, around the backside, and up through the hole made by the first piece of paracord. Then pull the Paracord braid tight evenly.
Step 4: Paracord Bracelet Instructions - Step 4
Now continue the paracord bracelet instructions, bring the first piece of Paracord across the front, lay the second piece of Paracord over the top of the first piece, around the back of the Paracord Bracelet, and bring it up through the hole made by the first piece of Paracord. more Paracord knots.
Step 5: Paracord Bracelet Instructions - Step 5
Continue braiding the Paracord, until you reach the other buckle following these instructions, Bring the first piece of Paracord across, and wrap the second piece of Paracord over the top of the first piece, then around the back of the Paracord Bracelet, and bring it up through the hole made by the first piece of Paracord. Get aCustom Paracord Bracelet.
Step 6: Paracord Bracelet Instructions - Step 6
Your Paracord Bracelet is almost complete, just cut the ends, and melt them with a lighter. If you have a Paracord Needle, run the ends back into the weave, then cut and melt. Your Paracord Bracelet should look like the picture below, This Paracord Bracelet was made with a Tracer. See the Viper and Sidewinder Paracord Bracelet. Check out ParacordTime.com, Next try the Viper Paracord Bracelet, or these otherParacord Projects.
