So, here we go: a paracord bracelet with a Monkey Fist knot acting as the button.
Remove these ads by
Signing UpStep 1Ingredients
-A pair of scissors or sharp Swiss Army knife.
-A lighter to melt fraying ends.
-A marlin spike or similar pokey object, used when dressing the monkey fist knot; it should be as tight as possible.
-A skully bead, available at craft stores near you; all kinds are available online, too.
-Time: 2 hours for first attempt
http://www.paracordmaster.com/index.php/beads.html
Just a note, you don't need two running ends to tie a monkey fist. You can tie a knot in the end of a rope, and then build a monkey fist around it.
However, I agree with another poster that they're very difficult to size out and get located right. Every time I've done a rope project with a monkey fist, it was always easiest to tie that first, then do the rest of the tying.
For extra weight (or size), you can also put a wooden bead or a steel ball in the monkey fist before tightening...
Have a happy new year!
http://www.instructables.com/id/Multi-Color-Monkey-Fist/
My first success from an Instructable - great work, people!
the weaving is accomplished by taking one side strand and placing it over the two center strands leaving a gap. the second side strand goes over the first side strand, behind the two core strands, and out from behind through the gap that was left by the first strand. pull the two outer strands to tighten.
by the way: if you use the same side strand you get a flat weave, and if you alternate strands then the braid twists into a double helix shape.
hope that helps
I remember seeing these at a Hobby Lobby which is a hobby shop in the New Mexico Area.
