I've been enjoying this site for long and have finally found enough time to write a first Instructable by myself.
I'll will share with you how to make a real paracord bullwhip.
It should not be that hard for those of you who know their way through ropes, knots and braiding.
I wouldn't recommend this as a beginner project though.
It involves careful and regular braiding of up to 12 strands a bit over 12 feet long, which can be a bit messy or frustrating if you're not familiar with manipulating such lengths of cord.
You will also need to know ( or be willing to learn) some 'advanced' knots to make it look nice, and I won't cover that lengthly point in this Instructable since there is already a lot of resources on that topic on the Net.
I however do plan on doing a few other Instructables on that topic if people are interested in it.
We will be making a 2.50m ( ~8.2ft) whip, from handle tip to fall, not including the cracker.
Take your time with this one, you'll get what you give.
It took me maybe a week or so worth of evenings to complete it.
The result was well worth it, this thing cracks loudly and easily as expected and it ended up being a very rewarding project.
I'd like to thank "Bullwhipcracker" for his nice info about whip making that served as an inspiration for this project and saved me some headaches about figuring out the correct lengths for the different steps.
I was unable to find a homepage or anything that links directly to his work to give him proper credit though.
Now, let's get to the fun stuff :)
Update:
Here's a short vid showing that it's indeed the real deal.
Remove these ads by
Signing UpStep 1You will need...
- Paracord ( lots of it ) I started with 60m (196 ft.) and had maybe 15m left after I finished.
But better be safe than sorry on this point :)
- 2m (6.5ft ) of some light chain, the kind you find on lamps or that holds your sink plug.
- Duct tape and/or electrical tape
- 1 "Big" Nail ( Big meaning that it would do the trick as a handle )
- Some medium width string to tie the cracker
- Something that cuts ( my trusted Surge in that case)
- Something that makes fire to neatly melt the ends of your butchered paracord.
A Zippo is a nice choice, it will get you a nice flame and stand on the desk by itself while you use both hands to melt/cut the paracord over the flame.
- Measuring tape
- Patience
Optionally you might find useful to have:
- Some kind of marlinspike needle for dressing the fancy knots.
- A file or some kind of grinder or Dremel tool to cut grooves in the "handle"
- A spot to tie the whip to while you're plaiting ( holding it between my knees worked well in my case ) you could also use a lightly tightened vice.
Also this project works with mainly gutted paracord so you will end up with vast amounts of unused inner strands.
Let me know if you think making a hammock, net or bag out of them would be an interesting Instructable :)
Your whip sounds great ^^
But unfortunately, I don't know of any ratio for this.
Especially since many things might make it may vary such as :your plaiting style , the initial materials, the thickness of your differents layers...
I think using simple ratios based on this example should be close to what you'd need, but i'd recommend extanding them a bit , just in case.
That's the only whip I've made so far so I lack data to make the estimates more accurate, but if you happen to try it with other lengths, I'd be interested in the outcome ( lengths you used, length reached, leftovers..)
I'm glad you like it, thanks for your support ;)
( You're from Poland ?Right? )
Even I didn't 100% follow the exact measurements I give here.
To make it neat , if the whip is 5 sections long,thinning every 1/5 will probably work fine for the guts, maybe with the end segment slightly longer than the others.
You might also want to add additionnal sections ( and a corresponding number of pair of strands to the plaits) to the whip If you want to make it longer.
Since they're 3 layers, when making each one, drop thicknes 1/3 way of the underlying layer to get an even progression.
I made a ( crappy ^^' ) diagram to better explain it below:
Black bars are the gut sections, blue is the first layer, red is the second one.
vertical green marks show points where the whip loses thickness, note that they end up evenely spaced.
I hope this helps.
( I was born in Warsaw btw ;) )
After perusing the comments for quite some time I realized no-one has actually posted a pic of a bullwhip they made using your directions.
So here is some photographic whippage for your ogle-ing pleasure. It aint perfect but neither am I. Your instructable was excellent, well written, easy to follow, at least if a dullard like myself could do it, well, you know.
Also thanks for your support, doing this instructable took some work, and i'm glad people find it clear enough to follow.
I hope you have fun with your hand made supersonic toy :)
I featured your comment so everybody can see the results near the top of the page. I also planned on using multiple color strands, but didn't have long enough strands of matching colors at the time.
How many orange strands did you use ? My guess from the pattern would be one ?
Very nicely done, and thanks for your support :)
The 100 % complete ones are shown in close ups, the 8ft blue one is gutted paracord with simple round diamond and tripled 4 strand plaiting on the handle, the black one is a 10 ft 8 plait "Indy" Bullwhip made of... the DIYer's best friend Duct Tape
I was wondering: how good does the duct tape one perform?
What did you use on the inside ?
It looks great.Did you fold the tape strips lengthwise to get a thinner non-sticky band ?
I
I guess you only used one ping doubled strand to achieve this pattern ?
( I'm stressing that so people could have various recipies for differnt patterns from the comments )
Nicely done!
brilliant set of instructions. Time estimate right on and what an excellent whip to end up with. The missus and I went into the back garden and were breaking the sound barrier within minutes. Excellent. Thank you
I'm glad you enjoyed it.
Any pics ?
Here are a couple of photos.
Rather than a nail I used an old kite strut for the handle. I lengthened the first four strands to run the length of the handle as I thought it would hold together better. To finish off I screwed a round head brass head screw up the center of the rod. I am contemplating doing a knot on the end of the handle but having tied it in larger rope the thought of doing it in paracord is giving me the willies. Maybe I will just polish the screw head and call it a day as it does look nice and works very well.
thanks again
Martin
I didn't have much luck with the knot you used to secure the cracker, so I made up my own. pictures and video below.
Seeing all those pictures makes me wish i had much more time to try out all those color variations.
The chain is used to weight the whip.
how long was the nail you used for the handle?
also, where did you buy your paracord?
BTW, great Instructable!
Just pick up what's available in your local area.It should be something that feels comfortable as a small handle, 1.5 to 2 times the length of your closed fist.
I live in europe (France) where paracord is really little known.
I ordered it online from a very small website specialised in importing it there for an decent price with no additional port: http://booshcraft.eu.
Since then i think you could also get it from ebay or amazon for even less depending on where you live.
I have two questions
1) Could you make a suggestion to modify this to be a stockman's whip?
2) Would you mind making the instructable that would show how to make the whip head. I have tried a couple of tutorials online and I have not gotten it right yet.
Peace, Andy
1) I havent tried it yet, but thought about it. The way I'd go would be:
- When making the inner layer ( the part where you'd tie the strands around the nail ) I would obviously remove the nailn and use doubled strands instead of individual strands.
Then I would make a small loop at the folded end by twisting a pair of them together. and secure them all together with a manrope knot or a couple crown knots.
Then i'd go on similarly to the rest of the instructions.
It's hard do explain in text, so here's a picture of sometihing close i found online.
Only picture this without the metal stuff, and with the braided part twisted instead of braided.Then a manrope knot where the green whipping is.
2 ) You mean the star knot for the handle ?
Unfortunately it's a knot that's easy to show but really hard to explain online.The ressource I give in the instruction is the really best I've found.
I'm afraid you'll have to try it out several times before you get it right, don't give up, it took me some tries to get it right for the first time, just pay real attention to every single word used in the tutorial.
Also, since I got my metal lathe, I was planning on making some sort of 3-in-1 whip handle.
It would be basically a snake whip but whith a hollow handle, and then you could screw in a hard handle to make it a bullwhip, or a piece witha loop on it's end to make it a stockwhip.But (unfortunately?) I've got soooo many other "new" projects to do before going back to whips and won't be putting that to test before a long time.
Have fun !
