3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paracord CamelBak Hose Cleaner
This instructable shows you how to clean the mildew, mould and accumulated dirt from the plastic hose on your CamelBak or other hydration bladder with nothing but some paracord (and some optional sterilization tablets).
I discovered this neat trick an hour before setting off on a climbing holiday after finding that my CamelBak hose was disgustingly dirty.
Being loathe to spend £20 for a brush on a wire to clean the hose and without time to get one I looked around for something that could clean the hose.
Paracord was the answer! A loose knot in the end of a length of paracord, dropped through the hydration bladder's hose can be drawn through slowly and bring all the gunk with it.
Here's how I've done it ever since.
Step 1You will need....
  • A dirty camelbak or other "hydration bladder" hose
  • Milton tablets or other baby bottle sterilisation tablets. You could also use mild soapy water though not too much or you may leave a bad taste. Definitely don't use bleach.
  • Paracord. About 10cm longer than the hose
22 comments
Feb 3, 2012. 5:16 PMdeaug13 says:
Couldn't have found your post at a better time. I have been racking my brain so I wouldn't have to spend money on what should be an easy fix. Can't believe I didn't think of paracord before this. That stuff is almost as universal as duct tape.
Dec 4, 2011. 12:48 PMrstupplebeen says:
I have been using this trick since you posted it and was just trying to clean a long hose from homebrewing and found that running water through the hose helps get the rope through.
Sep 22, 2011. 12:58 PMlalexander says:
this trick works with gun barrels too, exept i use weedwhacker line and melt the line into a little ball, then thread it thru a bit of cloth patch and pull it thru. the weedwacker line may work with your drinking hose. you might benefit from adding a scrap of cloth to the line when you pull it thru.
Sep 22, 2011. 1:06 PMlalexander says:
also, you can soak your hose in a more hygenic environment by using an empty wide mouth soda bottle. add the hose and cleaner ect into the bottle with the water and shake it, let it sit, shake it again ect.
you can also avoid introducing germs into your clean hose by swinging it to dry it inside instead of blowing thru it.
to clean the inside of hard to reach areas inside of your reservoir you can use dry rice with a little water and shake it to scour the inside. just wash it out afterward and get all the rice bits out. i use this trick with stainless steel bottles that have had coffee with cream in them. works better than a brush in some cases( specially with the narrow top bottles)
Sep 14, 2011. 2:40 PMsvataja says:
(removed by author or community request)
Sep 13, 2011. 3:25 PMbadpanda says:
Nice! I was using the alka seltzer looking things Camelbak sells to clean these, but using baby bottle cleaners will be way cheaper.
Jun 14, 2010. 8:00 AMourmoneypit says:
Excellent idea. Hoses are always a challenge, and your section of paracord can be sterilized, too. Thanks!
May 8, 2010. 5:00 AMqwerty29 says:
How often should you clean your camalbak if you only use water?
May 8, 2010. 7:10 AMqwerty29 says:
thank you!
Apr 25, 2010. 2:44 AMSurreyShepp says:
fantastic i dea i was about to go out MTBing over the surrey hills the other day and went to get my camelbak only to find it all gunked up and no kit to clean it. but now i have this way cheers
Apr 11, 2010. 1:51 PMkcls says:
Great idea. This would work for other tubes as well!
Apr 12, 2010. 2:19 PMkcls says:
Well, living on a boat and all, we have tubes coming out our ears! We have exhaust hoses, water hoses, fuel hoses, drain hoses and there are probably a dozen other that I can't currently think of.
Apr 4, 2010. 8:12 AMmeddler says:
Ah, clever. My cousin wastes so much money "buying" when there is a cheaper alternative. I was wondering just how to clean a hydration tube just the other day, and here you are. Thanks.
Apr 9, 2010. 4:34 PMNachoMahma says:
.  Great idea.
Apr 2, 2010. 4:20 AM=SMART= says:
Nice :)
Good idea
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
236
Author:Jayefuu
I am currently undertaking a PhD at the University of Huddersfield, England, looking at novel techniques in dispersive white light interferometry. Feb - April 2012 I was an artist in residence at I...
more »
