3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paracord ID badge Lanyard
For those wanting something a little different then the run of the mill trade-show ID lanyards.
This is a very simple project, matter of fact it was my first paracord project..
Inspired by Stromdrane , TyingItAllTogether and countless other paracord weavers out there.
Step 1Supplies needed
Supplies needed
To complete this project you will need the following supplies;
1 - Scissors or Knife (to cut the Paracord)
1 - Lighter(torch style) or Wood Burning tool (to melt the cut ends of the Paracord)
1 - 1" (2.54cm) 'Snap Ring' aka Key Ring
1 - 1-1/2" (3.81cm)Lobster Claw swivel (you can use any size clasp, I've found that 1-1/4" or 1-1/2" look the best)
*If you chose to do a single cord lanyard pick which ever works for you. OR you can use 2x of each, what ever makes you happy
5'06"' (1.676m)of Paracord for the main body of the ID Lanyard
8" (20.32cm) of Paracord for the 'comfort strap' bar You can use a longer length if you intend to remove it.
7' (2.1336m)of Paracord for the 'comfort strap' braid, this will yield about a 6-1/2" braid(depending on how tight you tie)
Basic knowledge of knot tying, you will be using the following knots.
Hangman's knot
Cobra Stitch also called a Solomon bar, square knotting, or a Portuguese sinnet.
Double overhand knot or a knot of your choice to secure the keyring/snap
4 comments
Oct 20, 2011. 9:06 PMCrucio says:
It looks really nice, Flahusky. I'd go with the double attachment points, too. :p
Jun 16, 2011. 4:41 PMcraftydan says:
um . . . did you SERIOUSLY put a hangman's noose around your neck as a lanyard without a breakaway?!?!?
I can see why you want the "comfort strap" to keep the cord from digging in . . . when it strangles you!
Jul 13, 2011. 6:27 PMThe Expert Noob says:
im actually a fan of the white collar hangman's noose. Its the one I taught in a meeting at work. I prefer my clip-on working in HR and all. people get angry.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Flahusky
