Paracord Keychain (Tutorial)
68,321
403
Published
Introduction: Paracord Keychain (Tutorial)
To make this you will need to look back at the paracord bracelet and know how to do the Cobra Stitch/Weave
Step 1: Supplies
You will need 2 different color paracord, any of your choosing
The orange paracord is 7ft and the blue one is a little bit over a foot
I like to make the rope size longer just to be safe
Step 2:
Grab the longest rope of your choosing and fold in half to have it equal length on both sides and should have a loop at the top
Step 3:
U will want to grab the loop and have it pointing towards yourself
Have the cord straight and the cords out to the side and should look like a T or Y
Make it the length you desire an it will be the length of the keychain
Step 4: Cobra Stitch
To start off you will need to know how to do the cobra stitch..if you don't know how, check out my paracord bracelet tutorial and come back to this
But if u do then great :D
Step 5:
Your doing the exact same stitch but just without a buckle
But once you have the first one done keep going to the desired length you want it. But make sure you leave a decent size loop at the end.
Step 6:
Flip over your keychain that you have so far..so that the loop is favoring away from you
Step 7:
This part is kinda hard
The stitch your going to learn is called the King Cobra Stitch/Weave (this is where the shorter string comes in)
Lay the shorter cord ontop of the keychain you made so far
Step 8:
King Cobra Stitch is basically the same thing as the Cobra Stitch but your just doing it ontop of the stitch you already made
Step 9:
You need to make the first part of the stitch but not the whole stitch like you see in the picture
Step 10:
Once you have that you need to do the second part of the Cobra Stitch under the shorter string so that it wouldn't be covered
Step 11:
Once you got the first one down you will need to keep going till you reach the end of your keychain
Going over, under, over, under, so on and so fourth till you reach the end
Step 12:
((I had to shorten mine and take it apart because I accident made it to long and ran out of string :/ sorry if I missed you up))
But once you finish it should look like the following picture
Step 13: Finish
Once you finished you need to cut and singe the four strands that are sticking out which should be the top & bottom strand
And the left & right strand
Step 14: What It Can Be Used For
You have a great possibility of where you can put or use it.
-add a key ring and add it with your lanyard
-add a key ring and make it a keychain
-add it to a book bag
Whatever..possibilities are endless
But thanks for checking this out
\(^0^)/
Step 15:
If your looking to get some cheap paracord like where I got mine
Check out this website:
http://www.wildbillwholesale.com/paracord.html
Type in wholesale paracord and it should take you to it
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Game Life Contest
      Game Life Contest
    3 Discussions
    Great instructions! Exactly what I was looking for.
    gevan
    3 years ago
    love tot make thuis in red
