Paracord Laced Pallet, Hanging Chair
 by Twotim221
Contest WinnerFeatured
Very comfortable, very easy to make chair from a pallet and some paracord.
I know that there are a lot of different kinds of chair instructables already, but I have never seen a chair like this before. It is so easy to make and it is comfortable because it conforms to your body. I don't know how I came up with the idea and as I was making it I wasn't even sure if it would work out. But it did and I am very happy with the results. So here goes- my first instructable.
This instructable will show you everything I did to make the chair, but I am sure you will find ways you can customize yours to meet your needs.
Step 1:
Step 2: Tools and Materials
Stuff you will need-
Tools:
Drill
Saw
Lighter
Sawzall (optional)
Materials:
Paracord
Pallet (I was able to get by with just one but it all depends
on how much usable wood you can get off of each pallet)
I used pallet wood because it is hardwood and free but, as with all treated wood, you need to use precaution when handling this wood. Make sure you are wearing a mask when cutting and gloves at all times. When you are finished with all the cuts and have drilled all your holes, it is important that you seal the wood.
I used paracord because it is small yet strong and does not stretch as much as other ropes. Paracord is also easier to work with because it doesn't unravel or fray like other types of rope, and because the ends can be melted to make lacing with it easy.
Step 3: Take Pallet Apart
There are many different ways to take apart pallets in order to use the wood for something else. I have  found that prying them apart causes a lot of damage to the wood and is a lot more work then is necessary. So, my preferred method is to cut the pieces apart using a sawzall.
All you have to do is cut through the nails that are holding it together and you are good to go (with minimal damage to the  wood). If you want you can pop the remaining parts of the nails out of the wood.
Just take the sawzall and cut right between the piece you would like to save (the top piece) and the thick frame. Try to cut just the nails and not too much of the wood. Once you get the hang of it it will go really fast.
Step 4: Cutting the Wood to Size
Now here is where you need to decide how wide you would like your chair. I guess you should base the size on the hiney that will be siting in it. With the pallet that I had I was able to just cut the boards right down the middle (20"). Butt the size is up to you :)
The amount of board is also up to you. I ended up using 16 boards for my chair.
Warning:
Make sure you look out for left over bits of nails in the wood as you are cutting.
Step 5: Marking Wood for Lace Holes
Now what you want to do is take one of the boards and mark where you want to put the laces.
I put my laces 1/2" in from the edge of the board and put them 2" apart.
Depending on how you would like yours to look you can make the laces further apart or closer together. As long as they are in far enough from the edge so that the board does not break once it has weight on it. Keep in mind also that if the laces are spaced further apart,  the boards will tend to pull away from each other more, making a gap where things might get pinched (fingers, "cheeks", etc.)
Step 6: Drill the Holes
Now that you have you holes marked you can start drilling. I used a drill press but a regular drill will work just fine.
I started by drilling all the holes in my first board and then I used that board as a jig to do the rest.
You will want a drill bit that is a little bigger then your paracord so that the cord fits easily through the holes.
Step 7: Start Lacing
Now comes the fun part. Start by placing two of your boards next to one another. Now lace the paracord through them just as you would a pair of shoes. Once you reach the end cut the paracord, making sure you leave enough slack to tie a strong knot at the end. Now you can pull the paracord out and use it to measure the rest of the pieces you will need. When you cut the rest make sure you leave a little room for error, it's better to have too much and cut then to have too little and have to start over.
Once you have cut your paracord to size it is a good idea to melt the ends so that it is easy to get the cord through the holes.
Now you can start lacing boards together.
Things to watch as you're lacing:
-Make sure you are paying attention to what side it up and what side is down so that you end up with all the good looking sides facing up.
-It  looks best to have all the knots on the bottom.
-Once you have finished a lace go back and pull each "X" to get the slack out
Step 8: Hang and Enjoy
Now all you have to do is hang the chair from whatever structure you have available.
I used some 2x4's between the trees in my back yard (not the prettiest but it works).
Just drill a couple of holes in each of the four corners you would like to hang the chair from and thread the paracord through them. I put the front cords back one board from the end so that it would be more comfortable on the back of my legs.
For a somewhat laid back chair attach the front and back cords further apart from each other with the back cords low, for more of an upright chair, like mine, put them closer together with the back cords high.
The whole thing is completely adjustable to your liking,so tweak it till it's comfortable for you.
Note: I used two strands of paracord per corner, which is strong enough to hold me, but you might want to braid more together for some more strength.
-Getting into the chair can be a little tricky (kind of like getting into a hammock) but once you do relax and enjoy.
Improvement:
I think I would stain the boards next time, this would look nicer and make the paracord stand out more.
1-40 of 111Next »
TheAntiHeroHimself says: May 4, 2013. 6:37 AM
I JUST finished my own chair! I haven't hung it up, because I'm a little limited as to what I can hang it on. I have no trees in my backyard, and even though my front yard has 4 trees, they're a bit staggered, so it's tricky. Not just that, but since it's in the front yard, I don't want to build a 2x4 rig that everyone will see. The only options I have are
1. Hang all 4 corners from 1 branch(I don't see that functioning properly, since it will be VERY uncomfortable)
2. Hang it from 2 branches, both on a different tree each. They're both parallel with each other, but are a bit far apart.
If I EVER find how to hang it(either today or tomorrow hopefully), I'll try and post a picture, but after accomplishing stuff I usually begin procrastinating, so we'll see how things go!
Twotim221 (author) in reply to TheAntiHeroHimselfMay 7, 2013. 5:12 AM
You could hang it from one branch, but you would need to make some sort of frame to run the corner ropes through.
j_man51590 says: May 6, 2013. 4:38 AM
Im in the Army and I made a chair for myself and a friend. Worked great! its awsome for when we go to the field and need something to relax on. Way cooler than a hammock and definately more interesting to talk about. Great Post!
dana-dxb says: Apr 28, 2013. 10:51 AM
nice i love it and it gave a good idea
thanx
Suvo1 says: Feb 5, 2013. 2:12 PM
wow, nice job.
GoneToTheeDogs says: Jun 23, 2012. 7:06 AM
Is there anyway you could give the measurements in the length of the cords and the distance between the front and back ones? I'm having a hard time tweaking mine just right. I just hung it straight from the tree branches. Once you're in it, it's pretty nice, but it's super hard to get in and out.
Overall, I love it! Once I really get the length adjustments down, I plan on making a nicer one for my grandmother as a gift. This is such a great idea! Always looking for ways to make use of all the pallets sitting around at work.
Twotim221 (author) in reply to GoneToTheeDogsAug 4, 2012. 8:10 PM
It is kind of like a hammock,just a little tricky to get into- just keep tweaking you will find the "sweet spot". I would love to see what your chair looks like, please upload a pic if you get a chance.
GoneToTheeDogs in reply to Twotim221Aug 5, 2012. 4:40 AM
Thanks. Will keep tweaking. Here's a pic.
TheAntiHeroHimself in reply to GoneToTheeDogsSep 29, 2012. 8:16 PM
Do you remember approximately how much paracord you used for yours?
GoneToTheeDogs in reply to TheAntiHeroHimselfSep 30, 2012. 11:45 AM
I don't know exactly, but 100' cord is definitely enough for one of these chairs. I don't think it's quite enough for 2.
TheAntiHeroHimself in reply to GoneToTheeDogsOct 6, 2012. 5:16 PM
Only 100'? That's MUCH less than what I thought it would be! Thank you for the input, now hopefully my chair will turn out half as nice as yours did!
TheAntiHeroHimself says: Sep 28, 2012. 10:29 AM
Do you have an estimation of how much paracord you used? I want a starting point on how much Paracord I should buy, because I buy my paracord locally by 100' sections.
jhuston2 says: Jul 2, 2012. 9:41 AM
THANK YOU SOOO MUCH!!!!!! My wife is going to love this, she is a huge book worm and she loves to be outside. We live in Maine so this can also work very well indoors during the winter months. What a brain storm I don't know why I didn't think of this. I have built a pallet work shed and look to other things for pallet ideas. Thanks again.
Twotim221 (author) in reply to jhuston2Aug 4, 2012. 8:11 PM
Please share a picture when you finish.
CobraStitch says: Jun 28, 2012. 6:01 AM
I own a Paracord buisness, but i've never seen something so creative.
Way to go!
denebrock says: May 5, 2012. 11:58 AM
I've been seeing a lot of neat pallet projects lately- I like the idea of reclaimed materials. Thanks for the great idea!
wildviolets says: Feb 28, 2012. 7:58 AM
OH THIS IS AWESOME....right up my alley. thanks for sharing...frankie
Takelababy says: Feb 7, 2012. 4:42 PM
Thanks. I was delaying dismantling a few pallets wondering how to do it without splitting the boards.
badwooki says: Oct 14, 2011. 12:24 PM
actually it is called both a skid or a pallet
Plo Koon says: Jun 8, 2011. 3:52 PM
i think it's called a "skid", not a "pallet".
mrflumps in reply to Plo KoonSep 1, 2011. 1:24 AM
its called a pallet in the uk /shrug
abadfart in reply to Plo KoonAug 3, 2011. 10:01 PM
it can be ether
The Expert Noob in reply to Plo KoonJul 13, 2011. 6:57 PM
what are the plastic one called with giant cup holders?
medicman in reply to Plo KoonJul 7, 2011. 1:27 PM
Hi,
I worked for 7 years in the warehousing industry, the unit pictured is definitely a pallet. A skid is the type with just two wooden runners along the bottom, no slats on the bottom tying the runners together on the bottom like you see on the pallet above.
Plo Koon in reply to medicmanJul 11, 2011. 3:32 PM
Ah.
Twotim221 (author) in reply to Plo KoonJun 10, 2011. 8:55 PM
Both are correct.
Plo Koon in reply to Twotim221Jun 15, 2011. 8:40 AM
Ah.
agrippatheperson says: Dec 21, 2010. 3:47 PM
I'm not sure if this actually matters to anyone, but having an odd number of holes causes the very middle point of your rope and your knot to be on opposite faces of the plank. Therefore, you cannot hide the middle point of the rope AND the knot, so your board will look like this:
X X X X X X I
with the 'I' being the middle of the rope.
if you have an even number of holes, you'll have the middle point AND knot both on one side, so your front side is like:
X X X X X X
Im sure this doesnt make sense, if you want I could try to make it less confusing.
freakyqwerty in reply to agrippathepersonJul 22, 2011. 11:32 AM
It makes sense to me though I didn't notice before you pointed it out. If I made one i'd do what you said though...
lspears1 says: Jun 20, 2011. 9:13 AM
Just a quick suggestion for chair padding. I have found that carpet padding works great. It is fairly inexpensive, flexible and can be stacked according to what you want. It is super simple to sew a cover for it too. I have used it quite successfully on several projects.
iminthebathroom says: Jun 11, 2011. 6:34 PM
On a second look this could be adapted to another variation. The pallet boards strung together would remain, but instead of suspending it from trees or what have you, make a suspension frame around it. It would be more or less just a chair after that but, it would still maintain that floating hanging sensation I assume you get from this. Either way, once again well done
iminthebathroom says: Jun 11, 2011. 6:30 PM
Now that looks awesome! Good work
bomboy422 says: May 21, 2011. 10:13 AM
pallets aren't treated, so i don't think it would last too long out in the elements, maybe a year ...great idea though
Twotim221 (author) in reply to bomboy422May 23, 2011. 3:40 AM
Actually pallets are treated- that is why they last so long outdoors. Most are made of hardwoods that are not pron to rotting also.
mattthomas992003 in reply to Twotim221Jun 11, 2011. 4:11 PM
i worked for a car dealership that kept their pallets outside next to the new tires and both seemed fine
Caboose98 says: May 26, 2011. 5:18 AM
So how many feet of paracord would you reccomend for this? I am only able to get 100 feet of it.... :|
Twotim221 (author) in reply to Caboose98May 27, 2011. 6:00 PM
You should have plenty for the chair, but you might have to hang it with another type of rope.
Caboose98 in reply to Twotim221Jun 1, 2011. 4:44 AM
alright thank you :D
Guuskeunen says: Oct 30, 2010. 6:25 AM
euh, i'm almost done but how long is the chair my length is 2.10meters
Twotim221 (author) in reply to GuuskeunenNov 8, 2010. 12:37 AM
Mine is about 5 feet long.
1-40 of 111Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
