I know that there are a lot of different kinds of chair instructables already, but I have never seen a chair like this before. It is so easy to make and it is comfortable because it conforms to your body. I don't know how I came up with the idea and as I was making it I wasn't even sure if it would work out. But it did and I am very happy with the results. So here goes- my first instructable.
This instructable will show you everything I did to make the chair, but I am sure you will find ways you can customize yours to meet your needs.
Remove these ads by
Signing UpStep 1Tools and Materials
Tools:
Drill
Saw
Lighter
Sawzall (optional)
Materials:
Paracord
Pallet (I was able to get by with just one but it all depends
on how much usable wood you can get off of each pallet)
I used pallet wood because it is hardwood and free but, as with all treated wood, you need to use precaution when handling this wood. Make sure you are wearing a mask when cutting and gloves at all times. When you are finished with all the cuts and drilled it is important that you seal the wood.
I used paracord because it is small yet strong and does not stretch as much as other ropes. Paracord is also easier to work with because it doesn't unravel or fray like other types of rope, and because the ends can be melted to make lacing with it easy.
I worked for 7 years in the warehousing industry, the unit pictured is definitely a pallet. A skid is the type with just two wooden runners along the bottom, no slats on the bottom tying the runners together on the bottom like you see on the pallet above.
X X X X X X I
with the 'I' being the middle of the rope.
if you have an even number of holes, you'll have the middle point AND knot both on one side, so your front side is like:
X X X X X X
Im sure this doesnt make sense, if you want I could try to make it less confusing.
I've made my chair but haven't hung it up yet (pictures will follow shortly!).
A few comments, apologies if I have misunderstood your directions. It's a great instructable and a great idea :)
As a needle I gently melted roughly 4cm of the rope with a lighter. This formed a nice needle so it was easy to get the rope through the holes.
OK, I've just used one piece of cord per "lace". The way I did it was measured out about 4x length of the pallet (roughly 4 metres) but I DON'T cut it. I threaded it up and tied a stopper knot at the end. There is now a load of slack and the knot is that the end. Pull this knot so it there is now slack on the other side of the pallet. Pull this slack back through the next hole and continue until you eventually get to the you began with. You can then cut off the amount you need to tie another stopper knot with. This way you don't need to guess how much rope you'll need and you don't have lots of wasted off cuts. It also means you get it all nice and tight!
As a side note, if you find you don't have enough rope to finish the lacing you can just feed more rope through from the main roll.
I laced my pallets with the standing on there ends, this gave easy access.
For anyone attaching a rope to just one pallet (the top one) at the top bear in mind it will take THE WHOLE WEIGHT. If the suspending rope is threaded through all the pallets the load is evenly distributed (correct me if I am wrong).
Also, this is a safety measure, since if one of your pallet failed the whole chair wouldn't fail catastophically (that is, split in two with you going thorugh it!). Instead it should hold up nicely and you'll know there is a problem (without lying in a crumpled heap on the floor).
Final note (that I can think of just now) is that paracord comes in varying strengths and while the "official" stuff is rated at about 250 kilos or something the cheap stuff MAY NOT BE. And for anyone that doesn't know, tying knots in rope reduces it's strength, sometimes up to 50%. But that's a whole different topic.
Pictures coming soon! And thanks again for your great build! :)
I actually made this and guess what... ... i made a foot rest and it is a great addition you should include that in your instructable.
Bye
