3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paracord Laced Pallet, Hanging Chair
Step 3Cutting the Wood to Size
Now here is where you need to decide how wide you would like your chair. I guess you should base the size on the hiney that will be siting in it. With the pallet that I had I was able to just cut the boards right down the middle (20"). Butt the size is up to you :)
The amount of board is also up to you. I ended up using 16 boards for my chair.
Warning:
Make sure you look out for left over bits of nails in the wood as you are cutting.
2 comments
Apr 15, 2010. 12:25 PMgeminijhall says:
I would recomend right before this step, or right after. If you have the apropriate tools (table saw) to make a tounge and groove on the long edge of each piece. that way the pieces will butt together and reduce any pinching of your back end while your trying to relax in your new hanging chair.
Apr 25, 2010. 9:35 AMTonkaDan says:
tongue & groove would actually ADD more pinching .. spacing the boards farther apart would eliminate any pinching
Apr 15, 2010. 12:35 PMgooseflight says:
Be serious, a tounge[sic] and groove joint is designed for flat surfaces, e.g., floorboards or shed cladding.
Apr 15, 2010. 6:35 PMJohnSalad says:
 I think he means a bead and cove not tongue and groove. Like what you use when you're building a strip plank canoe.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:Twotim221
