Paracord Net Bag With Buckle Interlocking
Published
Introduction: Paracord Net Bag With Buckle Interlocking
About: My name is Jonathan I love to learn how to making items.
Step 1: Supply Need
550 parachute cord string 100ft
Lighter
Tape measure
Trash can, laundry basket,bucket as base
Scissor
Adjust knob
Interlocking buckle
Step 2: Measure the Waist of the Base
First you need to get your tape measure to measure the waist of your trash can or laundry basket as your base. Then you need to gave some paracord string and place it under the tape measure and I recommend your add a extra length of paracord string.
Step 3: Install Adjust Knob
instill the adjust knob to make sure the paracord string doesn't fall off the from your waist of your base.
Step 4: Measure the Base.
In this next step use your tape measure to measure to draw and the bottom of the base of your trash can or bucket.
Step 5: Measure the Length of Paracord
Use the tape measure to measure the length of paracord and recommend add a extra length.
Step 6: Under, Throw,pull
Know you have your measured paracord put your paracord the waist line and take the two ends and put them throw the loop and pull tide.
Step 7: Corners, Side,
Continue to use step 6 to place around the corners ands edges.
Step 8: Complete Sides
Continue finishing the use step 6 under,throw,pull to complete this step.
Step 9: The Net Pattern
Hold two opposite strings and loop and throw and pull continue to do that until you a diamond design.
Step 10: Paracord Net Bag and Burn Ends
In this step you push adjust knob towards the waist of the bag to close the top. Grab the two ends of the waist line and make a circle and loop throw and pull into a ball cut the two ends and burn the ends so the cord doesn't unravel.
Step 11: Interlocking Buckle
First use the male part of the buckle and measure from the buckle to the bag. Second use the female part of the buckle and measure from the buckle to the bag.
Step 12: Cobra Braided With Interlocking Buckle
Next cobra braided with interlocking buckle
Step 13: (Optional)Double Cobra Braided
In this step you can double cobra braided if you what to. But if you what do it use the same cobra braided technique it will look more huge and strong and it is called double cobra braided but if you don't what to do that is fine.
Step 14: Complete Paracord Net Bag With Interlocking Buckle
You have just complete a paracord project you can use for gym or workout, camping or even a hiking trip. I hope you enjoy this instructable.
    • Game Life Contest
      Game Life Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
