3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paracord Newton's Cradle (Kiteman's Balls)
Paracord Newton\
Fascinating. Mesmerizing.  You can stare at it for hours.  Play with it all you want.  This device demonstrates the conservation of energy and momentum.  When you swing one ball and it knocks into the next, it will transfer the energy from one ball to the other.  Of course, we do have some real world friction and chafing from the paracord so that might prove to be an irritant and affect the performance somewhat.
This version of the Newton's Cradle consists of an uneven number of balls in a linear formation which are suspended by paracord from a structure that lets them swing freely between such supports.
I would think every Science teacher like Instructables member Kiteman or those of the scientific mind should have one handy to demonstrate some fundamental laws of physics.
Disclaimer: Ahem, it failed to perform as expected.  But don't let this stop you from having a good time building it, only make the necessary changes described in the text.
Please, no
Fn comments on this instructable, this is something completely different. The following instructable contains discussion of a frank nature and may not be suitable for all.  Pun accordingly.
Step 1Materials on hand...
For this project you need...
* Paracord or similar string/twine/rope
Hey, I found some paracord in cool Instructables reddish/orange.
* An odd pair of balls - dense spherical objects - should be an uneven number like 3 or 5.  I used golf balls, you will be might be lucky enough to have ones made of brass.  There do exist Newton's Cradles made with bowling balls so size does matter.
* Tape to cover the golf ball if needed
* Two dowels, sticks, pencils, chopsticks or drumsticks to use as horizontal support rods
* Cardboard and glue for the support structure.
* Picture of your favorite character for decoration.
35 comments
Mar 20, 2012. 10:33 AMilpug says:
could you drill a hole in the top and hook it up to an eye hook? That keeps you from having to balls in bondage.
May 17, 2012. 8:31 PMwoodstockbirdy says:
That's not inappropriate at all.
May 17, 2012. 8:54 PMilpug says:
No, it isn't.
Nov 23, 2011. 11:03 AMbakedicecream says:
FAIL
Aug 28, 2011. 7:42 PMDaniel Deacon says:
looks nice it might be better to use metal balls :)
Sep 23, 2010. 2:05 AMsuperMacaroni says:
At first, I thought these were hanging ice cream scoops covered in orange stuff.
Apr 15, 2010. 2:46 AMKiteman says:
>wince<
Anybody wishing to play with my balls more efficiently should try and make sure nothing soft gets caught between them...
The paracord is absorbing the energy of the impacts and releasing it too slowly.  That's why you get the inelastic collisions that make my balls stick together.
Maybe, instead of a monkey's fist, you could try a Turk's Head knot (same family of knots as the monkey fist) around the "equator" of the golf balls, leaving plenty of uncovered surface for collisions?
Plus, as somebody else said, use steel ball-bearings if you can.
Aug 24, 2010. 5:04 AMking kolton9 says:
im new to knot tieing (no boy scout Experecience)
Aug 24, 2010. 5:03 AMking kolton9 says:
but then where would the string hang it
Apr 26, 2010. 11:06 AMHiyadudez says:
"That's why you get the inelastic collisions that make my balls stick together."
Aug 23, 2010. 5:19 PMking kolton9 says:
how about crazy/hot glueing it together it drys quic so you don't have to worry about holding it and the balls together without the cord touching or drill a hole and take the cord and put it through anybody???
Aug 23, 2010. 5:59 PMking kolton9 says:
will it work???
Aug 23, 2010. 5:20 PMking kolton9 says:
quick
May 15, 2010. 3:52 AMcorey_caffeine says:
i looked at these comments expecting hundreds of jokes about kiteman's balls and was not disappointed
Apr 15, 2010. 3:04 AMWarlrosity says:
Playing with them for hours? Do you play with Kitemans balls much?
Apr 11, 2010. 2:03 AMskimmo says:
it doesnt demonstrate newtons pricaple, the ones in the middle should stay still
Apr 11, 2010. 7:55 PMskimmo says:
i dont under stand
Apr 12, 2010. 5:28 PMskimmo says:
you might get better success with fishing line, it wont be such a dampener
Apr 12, 2010. 9:06 PMskimmo says:
hmmmmmm i see
Apr 12, 2010. 9:25 AMStormdrane says:
Perhaps using ball bearings for the cores and then soaking the tied paracord with super glue would improve the effect.  The super glue would harden the paracord to reduce the shock absorbtion and the heavier/denser ball bearings might have enough weight to keep it going... maybe...
Apr 9, 2010. 4:46 AMBiggsy says:
Hours of fun for the whole family playing with Kitemans ba... I er mean...  a newtons cradle
Apr 10, 2010. 9:46 PMRavingMadStudios says:
Very ballsy project. Even though the final result was a little hairy, I bet if you gave your binding a little more scrotiny and scratched some of the excess wrapping, you'd get bouncier bits. Or maybe I'm just nuts.
Apr 9, 2010. 4:08 AMHiyadudez says:
Hehe :-)
5* and faved :D
Apr 8, 2010. 9:49 PMNachoMahma says:
.  Too bad it didn't work as hoped for but you did a good job of documenting what happened.
.  Did you have any problems with the balls hanging too low at higher ambient temperatures?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
247
Author:caitlinsdad
This author has not updated their profile. They might or might not get around to it sometime.
