Introduction: Paracord Shark Tooth Paracord Bracelet
Step 1: What You Need
Twelve feet of paracord
A buckle
Lighter
Knife
Step 2: Getting It Started
Find the middle of the cord and put it through the top of the buckle. Then take the ends of the cord and put it through the middle of the hole then pull it tight
Step 3:
Then take the ends and put them in the other hole on the buckle and adjust it to your wrist size
Step 4: The Knot
You take the right strand and put it over the first strand and under the second strand and leave a bit of a loop with the right strand. The left strand goes over the second strand and under the first strand and through the loop ten pull it tight
Step 5:
Then you do the same knot with the left strand starting and then the same again with the right strand first
Step 6: Finishing It Off
Cut of the leftover rope and fuse the ends an you are good to go!
Paracord Contest
