Tiny room with too many books, comics, cameras and other assorted miscellany. I like the idea of building my own furniture but as a Systems Engineer by trade I am far more at home with Matlab than a tenon saw (what is a tenon saw). I also have no technical knowledge of wood and related paraphernalia required to turn it into stuff.
Plan:
To build easy a set of simple to construct low cost collapsible shelves to keep my stuff off the floor.
This design doesn't use nails or screws and doesn't require any sawing.
Instead the design uses 22 holes threaded with paracord inorder to suspend the shelves.
Note: As I've mention I have no technical knowledge of carpentry, and a hazy recollection of 3rd Year Structural Mechanics so any corrections or tips no matter how trivial would be greatly appreciated.
Dan
Remove these ads by
Signing UpStep 1: Materials
Power drill with 5mm bit
30cm Ruler
Pencil
Scissors
Materials:
4 x Hardwood dowls (2.5 cm dia x 100 cm)
3 x Hardwood Wood Planks (100cm x 22cm x 2cm)
Sticky Tape
Paracord or similar
Note: My material choice was probably a bit conservative lighter thinner planks could probably be used just as effectively.
Visit Our Store »
Go Pro Today »
What is a tenon saw? No, the question is: What is matlab? If I did this right, you will see I tenon saw. I will now look up Matlab.
Thanks
Where would you use the boards and screws?
It stands up by itself but you have to be precised with the cord to get it to stand up completely straight.
