Introduction: Paracord and Pulley Hanging Table
Before going to bed I often like to work on my computer, watch a movie, read a book, or just enjoy a cup of tea. Juggling all of these things on a bouncy bed can be difficult and frustrating so I designed and built a table that can be raised and lowered over my bed to make my life easier. When I want to do something like work on my computer I simply lower the table to the correct height and go to work, and when I'm ready to go to sleep I raise the table out of the way and hit the hay.
In this instructable you'll learn the steps and techniques needed to make your own hanging table. This is a useful and fun project that can easily be completed over a weekend and shouldn't cost you more than 30 or 40 dollars.
Step 1: Tools and Materials
Not to many tools or materials for this project and most of the things you will need are readily available from your local home improvement store. Overall I spent about 20 dollars to make this table but I already had many of the things I needed from previous projects, (things like stain, polyurethane, screws, etc). If you were to start this project from scratch it would cost just about 70 dollars for the various materials.
Materials:
Note, Many of these tools were used for building the table top, If you buy a premade table top you can omit tools like the table saw, and the biscuit jointer).
Materials:
Paracord ($10) - Used for hanging the table, the ammount you will need will depend on the size of the table you make and the height at which you want the table to hang. for my table I ended up using roughly 60 feet of cord. Check out step 10 for a formula that will help you determine how much paracord you will need
Pine Board (8" wide X 10' long X 1" thick) ($20) - These are cut and combined to create the table top. Note that you could buy a premade table top or even salvage one from an old coffee table. doing so would save you a few steps and the use of a few tools.
4 Pulleys ($5) - The pulleys I used for this project were reclaimed from old windows which I purchased at my local construction salvage store for a few dollars. Note that each window has 2 pulleys so you'll need 2 windows to get 4 pulleys.
8 Eye Screws ($3) - The eye screws I used were #8 X 1 5/8" but you could use any medium sized eye screws.
Masking Tape ($1) - Used for guiding the paracord through the pulleys, see step 10.
Wood Glue ($3) - Used for building the table top.
Biscuits ($10) - Used for building the table top.
Wood Stain and Polyurethane ($12) - Used for finishing the table top. I used Minwas PolyShade Pecan which was a stain and polyurethane all in one, which worked well for this project as it saved me some time, however what stain and polyurethane you choose to use will depend on your preferences.
Screws ($3) - General Wood Screws used for mounting the pulleys to the table top. I bought a 500 piece variety pack of screws from Harbor Freight which worked well for this project.
4 - 3/8" X 2" Lag Bolts and Washers ($2) - Used to mount the table hanger to the ceiling, these will be driven through the table hanger, through your ceiling, and into the studs.
ToolsPine Board (8" wide X 10' long X 1" thick) ($20) - These are cut and combined to create the table top. Note that you could buy a premade table top or even salvage one from an old coffee table. doing so would save you a few steps and the use of a few tools.
Table Saw
Biscuit Jointer
Drill
Router
1/2" Plunge Cut Router bit
Combination Square (A.K.A Tri Square)
Measuring Tape
Paint Brush
Biscuit Jointer
Drill
Router
Measuring Tape
Paint Brush
Step 2: Making the Table
The table top was made from one of the 8" wide X 8" long X 3/4" thick pine boards. the board was cut in half to make two 40" long pieces and then the pieces were joined using biscuits and glue to form the table top.
Step 3: Preparing for Pulleys
For the table to raise and lower, and hang properly the four pulleys were installed into the four corners of the table.
Installing the pulleys proved to be a little challenging. The pulleys I used were designed in such a way that the wheel of the pulley extended below the case of the pulley, this met that I would have to remove wood from the table top in the locations where I wanted to install the pulleys so that they would fit properly. To remove the wood I used a plunge router equipped with a 1/2" plunge cutting bit.
After routing room for each of the 4 pulleys you could potentially install the pulleys however I suggest that you wait to install them until after you have applied finish to the table as it will make finishing much easier.
Step 4: Adding Rails
After routing the grooves for the pulleys I added a few rails to the table on the sides and back. These rails serve two purposes, first they will keep things from sliding off the table if it is bumped and second they will help to keep the table from bowing from time and use. The supports were cut from scraps of pine board and were fixed into place using wood glue.
Step 5: Making the Table Hanger
With the table basically ready for finishing, I turned my attention to the table hanger. the table hanger is mounted to the ceiling and holds the eye screws that that the paracord runs through to hold the table. As noted in the picture, the dimensions of the wood that the table hanger is made from can vary (I used 3" wide lengths of 3/4" thick pine) but it's important that the overall dimensions of the hanger are the same as the table (for my table this means a hanger that is 40" long by 18" wide). The reason the hanger needs to be the same size as the table is that the eye screws installed in the hanger need to be installed so that they are the same distance apart as the pulleys. Keeping the spacing the same will help to keep the paracord from slipping off the pulleys as the table is raised and lowered. more information will be given on the process of installing the pulleys and eye screws in step 8.
Step 6: Finishing
Finishing will largely depend on your personal preferences. Personally I prefer to stick with a two part finishing of stain then polyurethane but for this project I decided to break out of my comfort zone and tried Minwax polyshades, an all in one stain and polyurethane finish. Overall I thought this finish worked well for this project, although I don't think I would use it on something with more vertical parts as I did have some trouble with leveling and runs and drips on the sides of the table and table hanger.
Step 7: Installing Pulleys
With everything finished you are now ready to install the pulleys. Install them as shown in the pictures and remember to use good quality wood screws as the pulleys and the screws that hold them will be what supports the table top and anything placed on it.
Step 8: Installing Eye Screws
When installing the eye screws in the table hanger it is very important to consider spacing and the orientation of the screw eyes. consult the pictures and reference the tips below for information on installing the eye screws.
In total you will be installing 8 eye screws into the table hanger, 2 eye screws into each of the four corners. the idea here is that the paracord travels trough one eye screw, then down through the pulley on the table top, and then back up through the other eye screw in each corner. for more information on how to lace the paracord through the pulleys and eye screws please check out the next step.
Note the orientation of the screw eyes, move of them are facing the same direction except for the two on the left end of the hanger in the picture. these two are turned 45 degrees as this will be helpful when lacing the paracord in the next step.
Lastly note the distances (14.5" and 30"), these are the exact distances between the pulleys installed on the table top. it is very important that the eye screws are installed at the same distances as the distances between the pulleys as doing so will help to keep the paracord from slipping free of the pulley wheels.
Step 9: Testing It Out
With the table top and table hanger complete the next step is to give everything a test. I wanted to test the table to make sure it worked before drilling holes in the ceiling of my bedroom so I did a test hang in the stud ceiling of my workshop. Doing a test hang is advisable as it will give you an opportunity to check and make sure everything works prior to installation.
Step 10: Installation
After a successful test hang the table was ready for installation. The 40" length of the table hanger allowed me to span it over 3 studs (16" centers), making for a very strong connection i.e. I won't have to worry about having a table fall on me while I sleep. To attach the table hanger to the ceiling I used 2" long by 1/4" round hex screws equipped with large washers.
With the table hanger installed over the bed the next step was to start lacing the paracord through the eye screws and pulleys. Before lacing I estimated the amount of paracord I would need using this formula:
(the distance from the ceiling to the height where you want the table to hang expressed in inches times 9) + (the perimeter of the table minus one of the short sides expressed in inches) + (2 times the number of pulleys) + (12 to give you room for error) = the amount of cord you need.
When I plugged the numbers in it looked like this:
(60 X 9) + (98) + (2 X 4) + (12) = 658" which is equal to about 55 feet of paracord!
(Yes you will get a big number, this is because the paracord has to travel between the table and the ceiling 9 times and it also travels around the parameter of the table and through the pulleys ) If you do the math and you get something in the ballpark of 50 or 60 feet of paracord you're in the right area.
After you determine how much cord you need follow the last picture on this step to learn how to lace the paracord through the eye screws and pulleys.
Step 11: Finished
Thank you for taking the time to check out my Instructable on how to build a paracord and pulley hanging table. I hope you enjoyed this project and found the information presented here to be useful and informative. If you have any questions or comments please feel free to leave them in the comments section and I will do my best to get back to you as soon as possible.
Best Regards!
Best Regards!
