Paracord Bracelet
2,336
79
7
Published
Introduction: Paracord Bracelet
Simple paracord bracelet
Step 1: Materials
Clip and 15 feet of paracord
Step 2: Prepare Ends
Use a lighter to burn the ends. This will prevent fraying.
Step 3: Weave the Runs Between Clips
Leave a small end out . Running the cord back and forth between the clips. This gave me 7 lines on the front/top and 6 on the back/bottom. Keeping them all even. I measured 10 inches from clip end to clip end for the length.
Step 4: Start Weave Down the Runs.
Weave over under and back n forth.. Then tighten & repeat until you've done this throughout the entire thing.
Step 5: Back Weave
Back weave the same way you weaved through. This will help square up the weave pattern. Cut off excess cord and burn ends. Tuck ends into weave. You're done!
  • Make it Move Contest
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
7 Comments
This could very easily become a belt or a gear strap. Nice simple weave.
It came out to 9 inch bracelet..Looks like I over looked that. Edit time thx..
thanks I made a bracelet after reading how you did yours, but I made a jig to make it easier
cool. I'll bet it helped a lot. when they make rugs with this weave they weave it on a machine called a loom.
Maybe I'm not in-the-know with paracord, but I've never seen this weave pattern with paracord before. Great Job!
Its basically the same weave they use to make rugs.
