Paracord bracelet with a side release buckle
Step 6Continue knotting
Continue knotting
Keep tying the knots until you have filled the space between the buckle ends. The knots should be uniform from one end to the other. Tie each knot with the same tension to keep the them all the same size.
4 comments
Mar 16, 2010. 10:55 AMMinke says:
This looks like the exact same way to make a flat hemp bracelet.
Jun 25, 2011. 6:31 PMlwindom says:
That's because it is. :p
Nov 10, 2010. 10:10 AMEGT1984 says:
When I was making mine I wanted the knotted pattern closer together so I pulled the knots closer together. The end result was a stiffer bracelet with a (seemingly) more complex pattern. Simply hold the female connector and pull the knots down the bracelet to make room for more knots.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
796
Author:Stormdrane(Stormdrane's Blog)
"No matter where you go, there you are."
