Step 7Trim the excess cord and melt the ends
You can now use your scissors to trim off the extra cord closely to the last knot you tied. I trim one at a time, and use my lighter to quickly melt the end I cut, wait a second for the melted cord to cool just a bit and then use my thumb to press the melted end onto the surrounding cord so it hardens as it attaches. You must be careful with this step. The melted cord is extremely hot, and it's possible to get burned, so you might also try using a soldering iron or wood burning tool for the melting step if you wish, or even use something like a butter knife or the knurled section of a tool to flatten out the melted end of the cord to finish it.
An alternative to melting the ends, is to tuck/pull the ends under the last couple of knots. I have used hemostats to do this on the inside of the bracelet, then trim them to finish. It does work, and is just barely noticeable as the cords add a slight buldge at that end of the bracelet.
Great instructions! been wanting to make one for a while now. just need to get supplies. what is a store you can get the supplies at?
1.On the finishing knot, do you make any finishing knot before the trim & burn, or is it just "over/under, over/under, over/under, trim burn" (ie; no special knot needed)...I'm worried my last knot will work loose :/
2. You (and others) have said the variance between one's knots and another prevents a solid chart, where a 9" would use 9 feet....but does YOUR own knot stay consistent? Such as, if my 7.5" uses 6 feet of cord, do you find it stays consistent enough where you can keep a chart? I find myself burning through 10 feet for a 8 or 9", with a decent amount left over, but I have yet to do many repeats of the same size (I have been keeping notes on each....my neurotic side).
Again, thank you Stormdrane!
If I were tying a lot of paracord bracelets with the same cord(off a spool), consistency is there, but because paracord from different manufacturers can vary slightly in diameter/thickness, you can end up using different amounts for the same size/style of bracelet, so it would have to be a fairly comprehensive chart to keep track of the differences.
Some paracord may have a solid round feel, others a loose outer sheath that flattens out, and some are somewhere in between. Colors can vary by batch, even from the same manufacturer, so I've even seen distributors mention buyers purchase spools of cord to get consistency that you may not get with buying shorter hanks of paracord.
Some paracord bracelet sellers use jigs to help make consistent and accurately sized bracelets(example).
My b-i-l made me a jig, absolutely love using it!
Thank you again! I'm off to try your knot challenges on your blog :)
http://www.flickr.com/photos/43015024@N07/4208845902
If you use something like cotton, hemp, or leather for cordage, which burn instead of melting, you can alternatively finish a knotted bracelet or lanyard with sewing, glue, or tucking the ends of the cords to finish. The same finishes can be done with paracord for those that don't want to use the melting method.
