Paracord bracelet with a side release buckle
Step 8You're finished
You\
If you did everything correctly, it should look something like this finished one. Once you know what you're doing, you can vary the amount of cord used by making the knots tighter or looser and pushing the knots closer together as you go can use more cord.
A tip for paracord bracelets: If the side release buckle is large enough, you can loop the paracord around them again before you start knotting, to fill in the extra room on the buckle.
The 1/2" side release buckles are a tight fit for this, but will work, and the 5/8" size are just right.
This leaves a two strand core for the bracelet when you start knotting.
Now, you could also have a four strand core by starting with a lark's head on the first buckle end, double wrap on second buckle end(at your wrist size), run cord back to and over the first buckle end, then start knotting over the four strand core.
Or, for a six strand core, lark's head first buckle, run the two strands around second buckle(at your wrist size), back to and around first buckle(now has four strands around), then back to and around second buckle, and start knotting around the six core strands.
This gives extra cord in case you need it for whatever, but it also makes the paracord bracelets thicker and more rounded, which I personally didn't care for and that's why I stick with the two strand core. YMMV
20 comments
Dec 23, 2011. 7:38 PMOrigurumi says:
Great instructable! My bracelet turned out wonderful and I'm giving it to my dad for Christmas! Really easy to get the materials because I live right next to an army surplus store and took me under 20 minutes to make! Great job once again and thanks!
Jul 27, 2011. 5:54 AMBuffalohump says:
Great tutorial SD, thanks!
Jul 5, 2011. 8:08 PMTexican65 says:
Thanks for the great instructions...they were clear and concise. I just made my first bracelet and it came out wonderfully. I'll be giving some as gifts and even have a few people lined up to buy them. Can't wait to get the assembly line in full gear. Thanks, again.
Mar 3, 2011. 3:18 PMh2kkeister2002 says:
I just wanted to say this is by far my favorite way to make these bracelets. I've made 3-4 so far and I'm getting rather fast at it. Once you learn this method you can also go as far as using it to make waterfowl lanyards as well.
Here's a picture to show both of them mentioned above. Thanks again!
Jan 23, 2011. 3:08 PMhndhurd says:
Thank you! I found a demo on YouTube that was very helpful too!
Jan 22, 2011. 2:01 PMhndhurd says:
I have been making the 2 color bracelets and wondered if there was a more secure way to "tie on" to the buckle to get started. On occasion the knot is coming undone. I can't seem to find the instructions on this anywhere. Thanks!
Feb 22, 2010. 6:44 PMLocus0mega says:
Excellent instructable, very clearly set out. For the record, I found that the cord just wasn't melting enough with a Bic lighter [I haven't got a butane one!], but a soldering iron worked great.
Now onto the King stitch! :D
Jan 1, 2011. 4:39 PMradiantmatrix says:
A Bic lighter is a butane lighter. A Zippo or similar is a naphtha lighter.
The problem with Bic lighters isn't the fuel, it's the intensity of the flame and the challenge of holding at the right angle. I personally like to use a candle when I'm working with synthetic cord, as it gives me more control and costs less to burn than butane/naphtha.
Dec 11, 2010. 9:34 PMcalipber says:
Ok im like in panic mode right now, I purchased 3/8 buckles from your dealer site, but you suggest 1/2 or 5/8 will the 3/8 still work or did i just order the wrong set, please let me know asap im trying to do these for xmas gifts!
Aug 14, 2009. 9:21 AMstealthy329 says:
this is cool! but how is this a "survival" bracelet?
Oct 15, 2009. 8:15 PM2nd.LT.2011US.ARMY says:
550 Cord is just somthing you want to have on yourself any time in thefield. Where I train we call it dummy cord. It simply means if youforget you rifle we dummy cord it to you so it will always be withyou. 550 cord is a need in the field.
Jun 7, 2010. 7:18 AMdevildogff says:
haha. our instructors in infantry school just tossed them as far as they could and you had to low crawl to pick it up and low crawl back. i will agree though. you need 550 cord in the field. we used it all the time in afghanistan.
May 4, 2010. 7:31 AMcmwolo says:
I have two of these actually, but I bought them from SurvivalStraps.com.
And to think, I could have saved a ton of money by just making one myself.
Jul 11, 2009. 9:28 PMjohnboyrebel27 says:
I just made this bracelet. It took me about 20 min. tops. I am practicing wilderness self reliance and this will be a handy item to have if in a pinch. Worth its weight in gold!!!!!
Jun 16, 2009. 10:36 PMremoc8116 says:
Stormdrane you Sir are talented, I am the guy that was bothering you on the Spyderco forun. I have all the materials enroute to start making my bracelets. Keep up the great work, You inspired me.....
Mar 23, 2009. 6:45 PMabsolutecool says:
Should you take the strands out from inside the paracord or leave them? I just made my first bracelet....it is ok....and I took the inside strands out of what paracord I had lying around and it is flatter more than round.
Apr 6, 2009. 10:41 AMtommy2 says:
If your making these as "survival" bracelets, the inner strands are important parts to use if needed. A thought!
Oct 7, 2008. 11:44 PMsemper says:
I made one and it's not as thick as yours and i have normal mil spec 550 cord why is this?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
797
Author:Stormdrane(Stormdrane's Blog)
"No matter where you go, there you are."
