Paracord Wrapped Maglight (glow in the Dark)
29,903
261
8
Published
Introduction: Paracord Wrapped Maglight (glow in the Dark)
I purchased some glow in the dark paracord and thought it would be cool to wrap a flashlight with it. There has been plenty of times I haven't been able to find my torch in the middle of the night while camping, etc. Hopefully-this will help me find it when I need it.
The wrap used is spiral hitching. A great video on spiral hitching by TIAT can be found HERE .
Step 1: Tools and Materials
Tools and materials needed:
1 AA LED Maglight
2. 7 feet of glow in the dark 550 paracord (www.supplycaptain.com )
3. Scissors
4. Lighter
Step 2: Clove Hitch
Start out by tying a clove hitch on the bottom of the flashlight.
Position the knot at the end of the flashlight and tighten the knot. Leave about an inch of slack on the standing end for snugging/tightening later.
Step 3: Spiral Hitching
Rotate the flashlight and begin half hitching.
Bring the cord to the top of the flashlight and make a loop
Rotate the loop up and bring over the top of the flashlight
Tighten the knot by bringing the cord all the way down
Step 4: Rinse and Repeat
Continue the half hitch process for the remainder of the flashlight.
The spiral hitching will occur with each half hitch.
Step 5: Finishing Up
Make sure the flash light is in the off position (headlight full clockwise position)
Tighten the hitching so that it will not impede with operation.
Starting at the bottom loose end-tighten cord as much as possible (may have loosened during spiral hitching)
Leave a 1/4 inch of cord, and trim off excess.
Use your lighter to turn the 1/4 inch of excess into bubbling magma.
Use a wet finger to smooth the magma onto the other cords to lock it in place.
Repeat above process for the other loose end.
  • Oil Contest
    Oil Contest
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
8 Comments
you can also add in a lanyard with this for flashlight that don't have a connector on them. just use a thinner cord like one of the strands from the 550 cord and lay it under the weave with the bend in the middle at the top of the light and use an overhand not on the ends. bazinga, you now have a lanyard too.
I like how the glow in the dark parts line up ever so perfectly!
Just did this to my crovel with a dark blue/green color and it looks sweet! Nice design.
what keeps the paracord from sliding off the barrel of the maglite? thoure roughness of it? i have tried something similar with bic lighters and cant ever find a way to keep the cord from slipping off.
Make the knots tight-use pliers if necessary. The maglight knurling definitely helps. Try roughing up the surface a bit to see if that helps.
Over on candlepower forums there's a couple guys selling high output glow in the dark lanyard tubes to attach to your lights, whatever. I put them on all mine and they'll glow all night long. Maglites are slippery little things though.
Interesting-Ill check it out. Ill see if I can integrate it-thanks.
