Introduction: Paracord Wrapping a Knife Handle
When I make a knife, I usually use micarta or wood for a handle, but sometimes I'll do a cord wrap.
When people think of a cord wrapped handle they usually think of a single color wrapped circularly around the handle, BORING!
So I decided to come up with a good way of mixing two colors for a wrap, this is the second knife I've made with this method, the first one was black and glow in the dark paracord. I was sitting in front of the tv, a knife in one hand, and some glowing and some black paracord in the other, I started messing around, and this wrap is what I came up with.
Hope you like it.
Step 1: Supplies
ruler
paracord (2 colors)
lighter
multi-tool (or you can just get pliers, pointy pokey thing, and a knife for cutting cord)
Step 2: Cut and Gut.
Go ahead and gut the cord also, make sure any melted ends are trimmed and pull out the inner strands.
Step 3: Readying for Wrapping
Ducttape the blade (I hate cutting myself while wrapping a knife).
Push an inch or so worth of cord through the starting hole. This is where we need to think this through. Whichever side you put the strands on, it will create a bump on that side, so I always put them on the inner grip side of the handle. The inner side of the grip is the side where you fingers wrap around, not your palm. It's more comfortable to hold it with the bump on the inner grip side, so I always put it there.
Did that make sense?
Okay, after you push the end of the cords through the starting hole, take a drop of superglue, and glue the ends of the cords down, this just helps keep them tidy and out of the way. Just don't superglue your fingers together.
Step 4: The Wrap
Pull the cords around to the same side that the cord ends are on. Make sure the black goes under the orange, then pull it over the orange (just look at the pictures, I'm not really making sense here am I?).
Then you flip the knife over and do that knot on that side. Make sure you pull it tight. Then you just keep flipping and repeating.
Step 5: Entertainment
Step 6: Ending
Step 7: Resin Coating
Mix up a small amount of fiberglass resin, I used 1 oz, but 1/2 oz would have easily sufficed, I just couldn't measure that small in my mixing cup.
Use a cheap (I repeat, cheap) paint brush and carefully brush resin all over the cord. Let it soak in, and brush on more as needed. Then carefully clamp in vise to cure.
After a few minutes, remove knife and turn it over, that way any resin gathering at the formerly bottom end, will not cure into drops or bumps on the side facing down (did that make sense?).
