3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Parallel Parking 1-2-3
One of the more difficult skills to learn as a new driver is parallel parking.  Kiteman did an Instructable on it in 2007.  I wanted to add something I use to make it a 1-2-3 operation easier to learn.  Kiteman's Instructable was designed for the United Kingdom.  Mine is more for the USA, although basic principles could translate between the two.
(The photo is from Google Images.)
Step 1"1"
\"1\"
Find a space and pull alongside the vehicle at the front of your space.
I used red paper to represent vehicles.  The long green stripe represents the curb.  The smaller green rectangles are the front wheels.  Your vehicle should be away from the parked vehicles about the normal amount of separation you have when driving down the street.
35 comments
Feb 20, 2011. 11:51 AMsapar says:
But, it is still the same process. My recommendation would be that a new learner not attempt some of the tighter spaces until he or she has some practice. garry-potter-7
Nov 4, 2010. 1:59 PMMatthewEnderle says:
now remember... UCLA "Uphill-curb-left-always" for which way to turn your wheels.
Source: Driver's Ed --Current and TONIGHT!
Aug 31, 2010. 10:06 AMhackmattr says:
Its easy to parallel park after you've done it a couple times in your vehicle. My friend wondered how I fit my pickup in a spot where I had 2 inches in front and back of me. Took like two times backing up and forward. A pain is when a trailer is attached because the trailer moves different to what you think.
Mar 8, 2010. 11:19 AMlemonie says:
The theory's great, where people struggle is in the spatial awareness & coordination involved in doing the maneuver in reverse...
What angle of entry do you recommend - 45o?
L
Apr 12, 2010. 10:52 PMhastalavista says:
You said it, if you dont train your spatial awareness then all the theory in the world wont work.
Mar 8, 2010. 12:35 PMlemonie says:
You've brought up another helpful tip in "aim for the spot between the street side headlamp and center of the car behind", I think. If a person has markers or targets (e.g.) a sticker on the glass, they can use these visual references. Although these would be specific to the car.
L
Mar 8, 2010. 1:41 PMlemonie says:
Yes that's making perfect sense, stretched limos would be a pain I'm sure...
L
Mar 8, 2010. 2:15 PMlemonie says:
Maybe you could follow this with reverse-parking articulated-vehicles though?
L
Mar 9, 2010. 3:46 AMac1D says:
http://www.instructables.com/id/How-to-Parallel-Park/
This method also work fine ;)
Mar 10, 2010. 1:42 AMac1D says:
True, I missed it!
Mar 10, 2010. 10:17 AMKiteman says:
True, your method involves less wheel-turning, but it also requires a much longer space in which to park.
Fine for a learner, but not common in reality.
Mar 10, 2010. 5:10 PMrimar2000 says:
In this regard, some time ago I had an idea, Phil, and I want to know your opinion: Why cars are not manufactured with the direction on the rear wheels? It would be much easier to do maneuvers like parallel parking, and because the predominant traction is frontal, the mechanics would be greatly simplified. Surely it would have to be considered side effects as possible skidding in curves, but that should not be difficult to solve with current technology. Will I have to get to make cars?
(Respecto a esto, hace un tiempo se me ocurrió una idea, Phil, y me gustaría saber tu opinión: ¿Por qué los autos no se fabrican con la dirección en las ruedas traseras? Sería muchísimo más fácil hacer maniobras como la de estacionar en paralelo, y dado que la tracción predominante es la delantera, la mecánica se simplificaría notablemente. Seguramente habría que tener en cuenta efectos colaterales, como posibles derrapes en curvas, pero eso no debería ser difícil de solucionar con la tecnología actual. ¿Tendré que ponerme a fabricar autos?)
Mar 11, 2010. 8:19 AMrimar2000 says:
Remarkable that design in 1932, Phil. I had read of cars that had an attached system, one or two small wheels at rear and below, who came down to move laterally the tail of the car. My idea is different, it is to put directly all the steer mechanism on the rear wheels.
Mar 11, 2010. 4:17 PMrimar2000 says:
No, it woul be transparent to users. The car should be drived just like everyone else. So I say that perhaps unwanted effects will occur as a possible oversteer, tendency to skid, etc, which should be solved by the designers.
Mar 9, 2010. 7:36 AMmole1 says:
Thank you!
This is SO much better than the "...when you can see x in your interior rear view mirror..." instruction I got decades ago - back when cars were of more similar width and  height.  Maybe now I won't have to look for double spaces =D
Mar 8, 2010. 6:15 PMdchall8 says:
I've always targeted the headlight adjacent to the curb.  Every car has one and you don't have to guess where the center of the car is.  I'm teaching my daughter to drive right now with that method.  She got it the second time.
Mar 8, 2010. 10:21 PMdchall8 says:
Yes.  Driver's side mirror looking down the side of the car.
Mar 9, 2010. 3:44 AMac1D says:
How to make a proper parallel:
Find a spot,
Try to struggle your car in the parking,
hit other ppl bumper,
done.
Alway worked for me.
Mar 8, 2010. 11:39 AMLoneWolf says:
IT's about time somebody made this instructable :)
Mar 8, 2010. 6:11 PMLoneWolf says:
Yeah, I am going to be getting to do that soon :) That's cool, I'm sure in a little less than two years I'll be coming back to this instructable :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
