3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Parallel Port 3 Axis CNC Driver, Opto-Isolated, Unipolar Steppers
Step 11Software & BIOS Setup
This driver has been tested and works great with KCam. But most CNC programs (Mach3) work in a similar way and should also work fine.
Parallel Port is set up as follows, pins referenced are on the DB-25 port.
X Step - Pin 4
X Direction - Pin 5
Y Step - Pin 6
Y Direction - Pin 7
Z Step - Pin 2
Z Direction - Pin 3
Ensure in the BIOS that the parallel port is enabled, address set ( 0x378 is default ), and mode set to EPP or EPP/ECP
A short Tutorial on Setting the Home Point and Eagle CAM Processor Info and more KCAM setup info.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
