3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Parallel Port 3 Axis CNC Driver, Opto-Isolated, Unipolar Steppers
Step 5MOSFETs and 7805
MOSFETs and 7805
Find the 7805, its in the same package as the MOSFETs but is labeled "7805"
Its place is labeled IC2 in the illustration. The metal tab lines up with the black part in the illustration.
Solder in securely, and make sure that the center pin has a really good solder joint.
Then starting from one end, place and solder the MOSFETs. See the top-side illustration and align the tabs on the MOSFETs with the black part in the illustration.
note: The tabs on the MOSFETs must not touch, as the tab is probably tied to the drain and it will not function correctly. There should be no need to heat sink the FETs.
2 comments
Mar 24, 2010. 8:13 PMdablakh0l says:
I just noticed that R20-R25 in the layout do not match their placement in the schematic. Is the schematic needing to be updated to match the PCB layout?
Thanks.
Mar 6, 2010. 5:33 PMflothmann says:
Hi great pcb, please just consider add some HEAT SKIN (just a piece of aluminium) to prevent mosfet damage caused by overheating (when the current pass throught the power elements like the MOSFET´s are )
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
