3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Parallel Port 3 Axis CNC Driver, Opto-Isolated, Unipolar Steppers
Step 6Plug in the ICs, Interconnects
Opto-Coupler's are labeled LTV827
The 16-pin socket., labeled OPTO2, is shared by 2 8-pin opto-couplers.
The dots on the ICs go on the same end as the notch in the sockets.
The other 8-pin opto-coupler goes into the socket labeled OPTO
If you purchased a programmed and tested chip from my Store.
Carefully plug it into the socket, aligning the notch on the socket and the dot on the IC.
Otherwise, program a 16F870 with the HEX file in the .ZIP in step 1.
Check the readme for fuses or the image below.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
