But, It is a ponderable notion. And you could reverse the rotor, add a tail and yaw bearing and make a regular wind turbine.
Remove these ads by
Signing UpStep 1The alternator
I'm not really an electronics guy, so I stuck my meter in AC mode across the terminals, spun it with my fingers, and got a reading of 50 volts! On current it read .2 amps. Umm okay, never mind the meter, would it light LEDs?
So wanting to see if it would light LEDs I wired 5 red LEDs together, four as a full wave bridge rectifier and the fifth as the load. As you can see in the video and pics, it had no problem lighting those LEDs, nor the five super bright white LEDs arranged in the same manner.
I got the idea for using a fan when, a few years ago, I bought a small electric fan and walking to the car I noticed the breeze I was generating by walking slowly was spinning the blades of the fan.
I have some steppers laying-around, and your 'ible has got me thinkin'!!!
TANSTAAFL
Z = -[j]/ [(omega)*(Capacitance) or Z = 1/[(omega)*(Cap)] < -90 degrees
and an inductor is
Z = [j]*(omega)*(inductance) or Z = (omega)*(Ind) < +90 degrees
You tap energy off a condensing unit, you'll get less energy out of your process, and increase the amount of energy the condenser uses. There's just no way around it! There's no such thing as 'free energy".
One of the simplest and best examples I've seen was an article about 10 years ago about homes built in Italy in mountain areas with no electricity. It mentioned a small generator used for pumping water into a storage tank, lights, and charging batteries. The generator manufacturer sold a heat exchanger unit that used the exhaust heat (where about 80% of the heat from the engine is usually wasted) to heat an insulated water tank for heat later, washing, etc.
It wouldn't take very sophisticated technology to do this anywhere with even the most primitive set up, although if it is an Italian design it probably looks good, too!
'honeybees can't fly per law of aerodynamics'
dm, the energy being tapped is the dump/waste heat energy. there is no strain on the condenserunit as it is designed to push air away from said unit to remove the excess temperature, aka cooling effect.
if anything. the small fan blade assists in moving the air by deflecting it.
Not only does the condenser fan remove heat from the condenser via "forced convection", the system in which it operates is essentially fixed, and fan laws for a fixed system with turbulent flow applies. The change in air-horsepower as a function of a change in the system resistance of such flow (eg: more restrictive as a result of placing your device in the airstream) changes as a linear funciton if assuming constant mass flowrate.
Strain is a change in length over a unit length, and as a result of compression or tension of a member. Strain does not apply to a machine, in this case a heat pumping machine. You restrict airflow in a heat pumping machine, you will encounter an increase in the delta-Temperature (ie: leaving-entering air temperature) at a constant heat transfer rate according to a Sensible heat transfer (ie: another process).
The First, Second, and Third Laws of Thermodynamics apply to everything. There's no way you ... or a honeybee can get around it.
this device is utilizing the exhaust not the intake and was discussed
in the comments with trebuchet in june 2008. please read.
I typically don't like to use an "appeal to authority" argument ... but since you have ....
I see this as being a little misunderstanding about the law of thermodynamics, the fan laws, laws involving the continuity of mass, etc. ... in general, Laws of Nature/Physics ... not Man-made laws. Even with a minor misunderstanding of the Laws of Nature/Physics, the probably of Rub-Goldberg devices being proposed into society increases expotentially.
If you truly think you have engineered a devise that does not tap energy off of the condenser, then add several of your devices to the condenser outlet ... and do it again ... and again ... and again ... allowing you to save enough energy to bill back the utility companies. You'd be creating energy!!!! (a violation of the First Law of Thermodynamics).
It won't and can't happen, and because of the Laws of Thermodynamics.
Mel Presswood, P.E. ... I've been involved with pumping heat, thermodynamics, HVAC, and environmental control systems for over 40-years .. my "Appeal to Authority" argument.
Basically what adding a turbine to your AC exhaust does is literally make it harder for the AC unit to push the exhaust air out. This will result in one of two things as it relates to the AC unit (and these are the only options): if it's a relatively smart exhaust fan, it will increase it's speed to compensate for the lost air movement. If it's a dumb fan, it will keep cranking at the same speed/power, and the cooling capability of your unit will be decreased. Your AC unit will have to run longer to hit your target temperature, because it cannot cool quite as fast.
If you think it through a little bit, you just have to extrapolate from what you know to understand it won't save you anything. Start with the extreme of covering the AC unit. The heat exhaust is critical to cooling the house, so your AC unit does not cool anything without a way to exhaust the heat. Lifting the cover slightly to allow a small amount of air through will allow the unit to begin cooling, but it won't work well at all. Lift the cover further - say a foot or so - and you've got heavy restriction but it is really starting to cool things down. Lift the cover to 10 feet and it will run at almost peak efficiency, but you also have very little air flow.
Putting a turbine on the back of your AC unit is exactly the same as partially covering it. It adds restriction to the air flow, which means it cannot exhaust the heat as well, which means it loses efficiency.
The exact same thing can be seen in reverse in high power carburated engines. Hot rod builders remove the air filter to increase the flow, but they also cut holes in the roof and install flared intake pipes to maximize the air flow.
With no holes, it's still an open system. Air flows freely through the radiator and from under the car, into the intake which provides oxygen to the engine to burn the fuel. Cutting holes in the hood of the car alone increases the air flow, which means the engine has more oxygen for burning fuel. To maximize the air flow, they then add specially engineered flared intake pipes, which provide the best possible air flow into the engine.
They do the exact same thing with the exhaust, putting wide, straight pipes out from the engine to maximize the flow.
Obviously the AC unit isn't that precisely engineered, however any obstruction reduces the ability of the air to dissipate heat, which reduces the efficiency of the AC unit. At the same time, the obstruction makes the air being pushed out more difficult to push, so the fan either pushes out slightly less air or uses more electricity to push the air out a little faster, depending on how smart the fan is. The only difference between an obstruction inside a sealed tube attached to the exhaust and an obstruction sitting in the open air outside the exhaust is the amount of potential loss it can create. They both create a loss in efficiency, which cannot be recovered because the turbine is not even remotely close to 100% efficient. The laws of thermodynamics are pretty clear on this one, even if you don't see the relationship.
The only way I could see this being of any benefit is if you aren't the one paying for the electricity to run the AC. In that case, it's incredibly unethical, but it will result in a net gain for you (but not overall). And then, if you're going to do it, you might as well seal it off, because you'll collect a whole lot more energy that way.
It would take about 700 hrs to generate 1000 watts. 1000 watts is about 18 cents savings.
700 hrs. is about 2 month air conditioner operation in the summer. Remember air-conditioners are matched to be 1/2 time, meaning they will be on for 15 minutes and then off for 15 minutes.
You have about $ 20 in plastic ware in your project without the stepping motor.
You would have to produce 111,000 watts to break even. That is 222 month of operation.
Since we run air conditioners only summers, I use the 6 month rule.
222 month is about 37 years just to break even without any repairs.
There is only one problem, In order to get the wattage out the stepping motor, the condensing motor uses about 5-10 watts more per hr. than what you get out of the stepping motor.
You would save more money by using the heat of the condenser to heat water.
Just think,
1 ton in AC terms is 12000 BTU per hour.
My AC is a 1 1/2 ton unit or 18000 BTU. 18000 BTU is about 6000 watts per hour.
Remember air-conditioners are matched or designed to be 1/2 time, meaning they will be on for 15 minutes and then off for 15 minutes.
So the 6000 watts per hour going down to 3000 watts.
We all know that you can not regain 100 % of the heat, but lets say 50 % of the heat that would be 1500 watts per hour.
The heat can be stored in water tanks.
1 lb of water heated up 1 degree is 1 BTU.
If you have a water tank with 40 gallon ( 8.5 lb per gallon) and you increase the temperature by 80 degrees you can store the energy.
40 X 8.5 X 80 = 27200 BTU = 9066 watts.
This would cost more than your design, but could pay for it self within a few month especially if you are able to make it yourself.
broken printers
broken CNC mills(the big ones have bigger motors)
Broken plotters
Broken electronics that need accuracy
Cd-roms
floppy drives
others
i got mine from a broken scanner
