3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Parasitic Wind Turbine
Step 2The Rotor
The Rotor
In the vein of keeping the design simple I wanted to have a simple rotor. My solution was to pull the blade assembly off of a cheap box fan that had reached the end of it's life. The rotor had been attached to the fan on a 1/2 inch shaft. To accommodate the 5mm shaft on my stepper motor, I press fitted a half inch dowel into the fan and then bored a 7/32nds hole through the dowel, and split the end of the dowel with a razor saw to allow the use of a hose clamp to secure the fan to the motor shaft.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
