Park 52 Knex Sniper
Introduction: Park 52 Knex Sniper
The PAC's basic sniper rifle ,the "Park 52" has very much versatility ,comfort ,power ,and accuracy.
Range: 30-45 ft.
accuracy: within 1 1/2 inches from 20 ft.
power: through card board
strong construction
Jams occasionally. (sharpen your ram a little bit to remedy this)
bullets some times get jammed the fake barrel.
by-pod slips on smooth surfaces.
Good luck building ,be safe ,don't point at animals ,and have fun. psst remember to sneak up behind your friends and shoot the back of there heads
Step 1: This Isnt a Step I Just Wanted to Show You My "studeo"
tee hee
Step 2: Step1 the Fake Barrel
this step is unnecessary ,but it makes it look like the real thing so I say build it if you have enough parts.
lots of pictures... not having a fun time uploading you better appreciate my time doing this.
follow the pictures.
that was faster than I thought. he.. he..
Step 3: The Barrel and Its New System
this is a new style of the common magazine I'm going to call it the "breach magazine" i hope that many will copy and perfect it.
as for thew reason it dosen't work perfectly
1.I have no time tonight and if I get around it ill add some help
Step 4: The Body and Scope
1. first build thees small pieces
2.more small parts
3.scope pieces
4 put the scope pieces together
different view
6.the actual body part one
7. add the scope.
8.get this piece
9 connect it
10.add the fore grip
12.slip them on
15.get this piece
16.put ti on in the yellow box
17 different view the right side if you reverse all the blue rods and special part I told you to put on you can make the breach on th left side I like it better on the left since I'm right handed so if your a lefty reverse.
19. add this piece
20. connected
21. I think something got messed up
22. put the front mag wall in
23. get the mag and barrel ready this might be the hardest part to put together.
24. this is one angle of where it is positioned wen connected.
25.the side view
26.the next 4 pictures will give you an over view of what the gun should look like so far.
30. looks sweet so far.
Step 5: The Handle Frame
1. build every thing in the picture.
2.put two pieces together.
3.put the last one on.
4.put the part that looks like this on.
5.put the next one on.
6.put the piece with all the orange connectors on it.! build! build!
8.put the back of the handle on
9.then make the tan clips that are on it get stuck under a white rod.
10.put the front of the handle on.
11.put the trigger guard on
12. different view
Step 6: The True Trigger
the true trigger my mom finely got a new S.D. card reader so I can finish the instructable!
1. build the actual true trigger
2.connect it
3.connect it some more
Step 7: The Butt/stock
1.oh look an old picture of the butt these
3.use them to make this
4.then add another part
5.then add the blue rod with the two red connectors on it a blue rod going through the middle and the blue rod with the two orange connectors for the second time (on this step)
8.more build
9.use the parts you just built to build this
10.add more parts this using the parts from picture 7
12.add the big part that was last constructed
13.but the side on
14.position the back of the but like this
15.push together a bit connect all 8 connection points yep 8 wow in that little space
Step 8: Put It Alll Together
yeah the put it all together step.
1.lay out the gun parts
2.put the butt and the handle part together but the barrel on the boddy
4.but the two parts together
I got to go to bed........... pictures need to up load....yay they did!
Step 9: The Ram
its the same as the morretties with out the string.
1.): do you not understand? pm me or don't build knex.
Step 10: The Bi-pod
here is the step where you build the bi-pod. brb I got to eat dinner PIZZA!
1.this is the bi-pod don't build
2.this is the 3 mane sections of the bi-pod. don't build
3.this is one of the mane sections broken up. this is what you build, build it twice.
4.attach the two peaces from picture 3 do this twice. these
6.different view.
7.put them together.
8.put it together more
9.put the piece from pic 4 on the part you just built
10.put the second side on
11.this is how you attach the bi pod.
12.its attached and so is the ball joint connector
this is what the ball joint connector will make it do. it will hold up so it looks more realistic.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    I have a question, you see I don't have any ball joint connectors, can I do the build without them?(that and I don't really care if the gun doesn't work, Im using it for display)
    Never mind I modified so that it would
    How is it supposed to shoot??
    I've made this before. I don't really see what the issue is, because the trigger works fine.
    nice gun, but could someone plzzz give me a part list, i want to knew if ill have enough
    ps. can u sub the blue conectors (circluar ones) with white ones?
    Yes you can those blue were a substitute for white ones. only do it on the fake barrel. the butt and the upper part of the body.
    i like pizza too. Pepperoni or spicy chicken my favourite.
