Particle Photon and Linkit One Serial Communication
Published
Introduction: Particle Photon and Linkit One Serial Communication
About: Eat*Sleep*Code Repeat
The Linkit one is a great board and the best part of it is it is portable and being portable it, is great to design wearable devices using the micro-controller. Another cool microcontroller which I work with is the Particle photon, this is similar to the linkit one and is really tiny and has on board WiFi module. In this instructable I'm going to show you how to setup communication between the Linkit One board and the particle core. For this instuctable I will be showing you communication via serial interface and in the next instructable I will show you how to communicate wireless over WiFi.
Step 1: Tools and Components
Here is a list of all the components required to get started with the project,
Linkit One
Particle Photon
Breadboard
Connecting wires
Micro USB Cable
Step 2: Serial Communication
Serial Communion is a common standard communication of communicating in a wired interface it is most commonly used while working with a arduino. It uses two pins for communication TX and RX pins, to communicate it has different BAUD rates for communication.
Step 3: Circuit
The circuit is quite simple all the connections that need to be done is
connect the TX pin or D0 from the linkit one to the RX pin or the particle core
connect the RX pin or D1 from the linkit one to the TX pin or the particle core
You can also connect the power to the spark core via the Vin pin and the particle photon is capable of handling voltages of up to 6V.
Step 4: Code
The code can be found below and you will require a modified Arduino IDE to work with the LinkIt One board to upload the code.
Linkit One
include
SoftwareSerial ser(0,1);
void setup() { Serial.begin(9600); Serial.println("SERIAL: BEGIN");
ser.begin(9600); ser.println("SOFTWARE SERIAL: BEGIN"); }
void loop() { if(ser.available()) { Serial.print("writing to serial"); Serial.write(ser.read()); } }
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
