Parts Cleaner
32,918
154
26
Posted in WorkshopTools
Introduction: Parts Cleaner
About: If it breaks, fix it. If it works, take it apart. If it can be bought, make it. If it doesn't exist, create it.
Quick and easy parts cleaner.
Items required.
Old coffee tin (Keep the can opened lid!)
Long bolt.
Cleaning solution
Tools required.
Drill
Vise/pliers
Step 1:
Fold the edges of the can opened lid upwards with a vise or pliers
**be careful of the sharp edge**
Drill 1/4" Hole into the center of the can opened lid.
(then drill several surrounding drain holes)
Fasten the end of the bolt to the lid with 2 nuts.
Step 2: Load Cleaning Tray
load cleaning tray with parts.
Fill the coffee can with a cleaning solution/solvent.
Step 3: Submerse Parts
Fully submerse the parts in the solution. (Evaporust in this case)
Put the plastic lid on.
set aside.
Just use the bolt head at the top to pull the parts out and dry.
No mess!
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    26 Comments
    A cheap cleaner used for rusted tools would be apple vinegar from the $1 store - one gallon cost $1 & takes most of the rust off - a little elbow grease with a pad will take off the other 10%... It is toxic free...
    Cool. Exactly what i needed. I need to remove some rust from tools. I have some solution that removes rust.
    Great job! Can't wait to make one. Oh, how I miss Tim Horton's. *sigh* Get my fix when visiting family in Canada.
    I also miss Harvey's hamburgers and the Poutine...
    I use Dawn dishsoap & water for parts cleaning & heavy grease removal. Almost any brand of dishsoap will do the job becxause they are formulated to cut grease (doesn't matter if it's petroleum based or from cooking). For small parts, use plastic storage containers with snap on lids from garage or yard sales cheap & when they wear out or start leaking, use them to store those small nuts, bolts or screws that have accumulated in the bottom of your workbench drawers!
    I found two web sites that claim to be the home of Evaporust. Do you happen to know which is the genuine article?
    http://www.orisonmarketing.com/
    Orison Marketing is the mother company of Evaporust. Great product and good people.
    great ible! got me thinking , what would happen if i attached a vibrating sander to this-? --super- sonic -soaker!!!
    for rust removal, instead of special solutions, you can also use 10% citric acid (by weight) mixed with regular tap water, works better if it is warmed up a little bit (40 degrees C)
    I like it. the best ideas are simple, effective and innovative, and cheap. This ticks all the boxes. great idea and ideal for finnicky gunsmith parts and small, easy-to-lose bits 'n' pieces of small mechanical devices.
    Clever. And you made it yourself, without buying one.
    This way you don't have to have your fingers irritated by too much cleaning solution (as when you'd have to reach into a can to retreive parts).
    BTW, is that handle what a country boy Frenchman might say? Kinda like "hayell yes!" ?
    Joseary had a good idea for the wire mesh basket.
    What's the cleaning solution made from?
    My kind of project...Recycle....5 stars...
    Thank you for this plan. I've been considering buying a cheap parts cleaner but won't have to now. I'm definitely making one of these.
    Great idea, thanks!
    I googled EVAPO-RUST and found what seems to be a SUPER PARTS CLEANER.
    I ordered a gallon ($28 incl shipping). It sounds fabulous since it's non-toxic.
    jbs/
    Elegant and a great use of old resources. I like it. Thanks
    Wire mesh shaped as a shallow basket with two washers for the bolt and nuts to grip should do the trick and make the magnets unnecessary. That way the "gunk" remains in the can to be strained an disposed latter. Also, the "basket" can be flushed with water and/or dried with compressed air.
    Nice and clean idea. Thanks.
    Perhaps add a strong magnet to the bottom to help keep the parts on top of the tray? I have a feeling it would get very dirty.
