I needed something to organize small loose parts, so I designed a segmented tray (with a lid) and printed it with a 3d printer.
Design and print files can be found here:
http://www.thingiverse.com/thing:39041
The lid (black in my model) sits under the tray, but goes on top if you want to stack several trays.
elabz says: Dec 30, 2012. 12:35 PM
I wonder if 3D-printing a form for a vacuum-formed parts organizer (basically, same as this tray but with air evacuation holes) would make more sense in terms of costs/time/effort/repeatability ? Then the trays (unlimited amount of) could be made of styrene sheets - the material they are very often made of anyhow? The form would need to be printed from a material that holds temperature well but I think it's doable.
Madrigorne in reply to elabzJan 2, 2013. 11:54 PM
only if you have access to a vaccuum former. I can see what you mean though.
anode505 in reply to MadrigorneJan 4, 2013. 4:43 AM
Pretty easy to make one. Just a frame for the sheet, the mold, and the vacuum box which from what I've read a shop vac works well. Toast up your sheets in the oven and go.
GimmeADream says: Dec 30, 2012. 10:06 AM
We have a 3D printer but to make a small tray would be so expensive. It is easier to pick up a few at the dollar store. That is..., unless you were using the project to learn how to use your printer. If that is the case, than Good Job!!!
anode505 says: Dec 30, 2012. 6:23 AM
Nice. Like the color combo too. But the time to print one out kinda makes it prohibitive.
One saying that comes to mind with the 3d printers is :
"Give a kid a hammer and everything looks like a nail."
MikeTheMaker (author) in reply to anode505Dec 30, 2012. 7:17 AM
It does take a while to print . . . but I just press the "build" key and come back later. For me, the print time isn't a big issue unless the printer is backed up with projects.
ndpmcintosh says: Dec 30, 2012. 5:09 AM
Those are nice and they look sturdy and durable. Which leads me to ask the inevitable question, how much did they cost in materials?
MikeTheMaker (author) in reply to ndpmcintoshDec 30, 2012. 6:50 AM
About $1.25 for the tray, $.75 for the lid.
privatier says: Dec 29, 2012. 10:12 AM
For those who cannot afford a 3d printer, I recommend the storage containers from Harbor Freight, starting at $2.49.
UOS says: Dec 24, 2012. 2:14 AM
Well I need to buy a 3D printer but they are so expensive :( Guess I have to speed up my desktop-CNC project 'cause I need drawers like these :) Good 'ible thanks!
MikeTheMaker (author) in reply to UOSDec 24, 2012. 6:08 AM
Thank you! This took about ten minutes to design--these machines allow one to move from a thought to a tangible object with great ease. I believe the cost of 3D printers and desktop CNC machines will come down quite a bit--hopefully soon :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
