Introduction: Party Bunting
A great way to let everyone know where the party is or just as a decoration in a kid's bedroom.
It is quick and easy way to make this personalised, reusable bunting.
Step 1: Making the Pennants
1. We drew ours in MS Word* and used the Format Borders and Shading option to fill them in pretty patterns and girly shades.
Alternatively, you could cut triangles from old magazines, giftwrap, posters etc and use a contrasting colour to add the letter of your choice.
2. Laminate
3. Use a paper trimmer to cut out the pennants.
*more detailed MSWord instructions:
Select Basic Shapes from the draw toolbar. Choose triangle. Drag to fill page. Use FreeRotate to turn so that pennant points downward.
Using Format Autoshape option, on the colours and lines tab, use the fill effect option to select the pattern and colour.
Use Insert Text or Insert Wordart options to add the required letters.
Step 2: Assembling the Bunting
1. Punch a hole at the top left and right edges of each pennant.
2. Work out how much ribbon or string you will need.
You will need twice the width of each pennant + a pennant width for each space (e.g. between 'Happy' and 'Birthday') + sufficient ribbon to fasten at each end.
We used florists ribbon because if is waterproof, cheap and colourful.
3. After leaving enough fastening length, start at the first pennant in your message. It looks neater if the knots are at the side of each pennant and the ribbon between each knot is at the back.
4. Leave a thumb space between each pennant and a pennant space between each word.
Step 3: Hang in Your Chosen Place
You're all done.
