Password Program
Published
Introduction: Password Program
This is a pretty simple program that uses the CommandPromt (CMD). This program let you access passwords fast and easy. This is fairly safe because it does'nt use any online service, so you can use it offline!
Hope you like both the tutorial and the program, because it took some time to make
Step 1: Turning a .txt File Into .bat
If you already know this part skip it.
Open your .txt document then choose File -> Save As -> Just add .bat on the name of the file. You can change it if you want!
Step 2: Editing the File
Now you should see that your file has transformed into this weird thing with gears on it. Right click the file and press the second option (picture)
Step 3: Some Coding!
Now we will start with the commands
@echo off
title -*-PASSWORD PROGRAM MADE BY AXBITE-*-
color a
Step 4: Coding :D
:A
echo enter password to activate program
set/p "pass=>"
if NOT "%pass%"== "PASSWORD" goto :FAIL
goto :success
Step 5: CODING :)
:FAIL
echo invalid password.
goto :A
:success
Echo you got the right password!
Step 6: Much Coding
Here comes a long one
:again
Echo enter command if you need help type help!
set/p "command=>"
if "%command%"== "end" goto :end
if "%command%"== "END" goto :end
if "%command%"== "add" goto :add
if "%command%"== "help" goto :help
if "%command%"== "list" goto :list
if "%command%"== "ADD" goto :add
if "%command%"== "HELP" goto :help
if "%command%"== "LIST" goto :list
if exist %command%. goto :show
echo invalid command or Site
goto :again
Step 7: Another Looong One!
:add
echo enter name of site
set/p "site_name=>"
if exist %site_name%.
goto :site_exists
echo enter password
set/p "site_password=>"
echo enter username
set/p "site_username=>"
echo site name: %site_name% > %site_name%.
echo username: %site_username% >> %site_name%.
echo password: %site_password% >> %site_name%.
goto :again
Step 8: A Short One
:list
echo --------------------------------------------------
dir /B *.
goto :again
Step 9: A Bit Loong
:help
echo * add/ADD - Adds an website, password and username!
echo * end/END - Stop the program
echo * help/HELP - This page!
echo * list/LIST - Lists all the websites, not passwords!
echo * "website" - write website and the username and password shows up!
goto :again
Step 10: The Last One
:show
type %command%.
goto :again
if "%end%"== "end" goto :end
if "%end%"== "END" goto :end
:end
pause
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    4 Comments
    Hint, use:
    If /I "%command%" equ "end" goto :end
    /I will turn it into a case insensitive compare and you don't need to check for both upper- and lowercase.
    Nice
    Thank you
    No problem :D
