Pasta Drying Rack
1,167
39
Published
Introduction: Pasta Drying Rack
How to make your very own pasta drying rack.
Step 1:
Saw up your timber into.
-two lengths 400mm long and 29mm square,
-one length 390mm long and 29mm square,
-one length 330mm long and 29 by 36mm rectangular.
Four pieces total.
Step 2: Sanding
Next give all your pieces of wood a sand.
I would highly recommend using an electric sander as this will speed up the process.
Step 3: Dowel
Cut up all of your dowel
You will need,
-Two lengths of dowel 10mm round and 350mm long,
-eight lengths of dowel 10mm round and 600mm long,
Ten pieces total.
You shouldn't need to sand this dowel because it is already round, however if there are any rough patches I would recommend smoothing these.
Step 4: Marking the Wood
Next mark the holes for your dowel, twelve in all.
Step 5: Drilling
Drill out all of your holes.
Be careful while drilling the two supporting pieces because you only want to drill these ones 20mm deep.
Step 6:
Here is what the wood looks like when drilled.
Step 7: Gluing
Next center and glue the two supporting feet to the cross bar, you will need to clamp these ones.
Step 8: Dowel Frame
Center your eight pieces of dowel.
When you glue these into place remember to pull the dowel out 25mm before you apply the glue, wipe the glue all the way around the 25mm section and push into place.
Step 9: Final Assembly
Wipe off any excess glue and push your two supports into the holes in the base, pick up your top frame and slot into the standing up lengths of dowel.
You have now completed this wonderful how to, I hope you make your very own one as this is very useful for drying pasta.
    • Pets Challenge
      Pets Challenge
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    Just what I was looking for. Thanks.
