3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Patch a Leaky Air Mattress, Inflatable Boat, etc.
Step 10Clamp It
Clamp It
To make extra sure, I'm using C-clamps (G-Clamps in other countries) to maximize contact while things set up. You could also stack some books on it or whatever is handy.
After an hour or so I took the clamps off and put the thing in the sun to drive off the braindamage solvents.
And that's it! It holds air and works fine!
If your patch leaks you can heat it up with an iron or hot air gun and squish it down. The melting point of the cement should be slightly lower than that of the sheet materials.
If that doesn't work, you can either peel it off and start over, or patch the patch.
1 comment
Jul 8, 2009. 10:16 AMph2692 says:
JUST when I needed to patch one...Thank you. Noe if I can find some glue!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1252
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
