Patch a truck bench
 by Zibodiz
Featured
I just bought a used truck in great shape, except for a nasty hole in the bench seat.  Thankfully, that's pretty easy to fix.  Of course, this isn't for show cars, but a work truck doesn't need to be pretty; just functional.
Step 1: Materials needed
First, you need some material to to use as a patch.  Denim is my favorite patch material, because it's strong, and it's easy to get.  Everyone wears jeans, and they all wear out eventually.  When they do, save them; they may have holes in the knees, but there's still plenty of good fabric there for patches.  This patch came from the back of a leg from an old faded pair I stopped wearing months ago.
Just lay the pants over the damaged area, and cut around it.  I like to leave about 2" of material past the edges of the hole on all sides.  This allows some extra for the hem, plus it makes sure that when I sew it down, I'm sewing into good material, and not part that's about to fall apart.  Next, make sure you have rounded corners.  If you leave a sharp corner, it will tend to get caught on things, no matter how well you sew it down.
The other three things you will need are curved needles, ultra-heavy-duty thread, and some foam (I used a mattress topper).  You will also need a sewing machine and regular thread.  Oh, and you'll need a truck with a hole in the seat ;-)
bigtreehouse says: Oct 4, 2012. 8:15 AM
Love it... my seat is more duct tape than leather. I would have to make one really big patch.
Zibodiz (author) in reply to bigtreehouseOct 4, 2012. 10:22 PM
Duct tape: the handyman's secret weapon!
--shamelessly stolen from my hero, Red Green
kdf.inc1969 says: Sep 20, 2012. 8:39 PM
guess who has a hole in there truck seat??? I DO !!! guess who has worn out jeans... I DO !!! thanks for the instructable. do you think the patch would work with vinyl seats or would you recommend something different?
Zibodiz (author) in reply to kdf.inc1969Sep 21, 2012. 12:13 AM
Vinyl can tend to tear loose a little bit easier than woven fabric, but from my experience, I'd guess that it should work just fine. It may be a little harder to pull the needle through, so aim for a narrow, sharp needle. If you want to be really sure, you can cover the stitching with vinyl cement. I've found it at Autozone before, for patching convertible tops. I think I got an 8 or 12 oz. tube for about $5.
Let me know how it turns out if you decide to go for it :-)
kdf.inc1969 in reply to ZibodizSep 21, 2012. 4:42 AM
ok will do. the vinyl cement is a good idea. im planning on recovering or replacing the seat if possible so doesnt have to be nice looking
pbates123 says: Sep 9, 2012. 12:56 AM
Great idea and good instructable.
A couple of idea's first you might try the die on a patch of the material and check it against seat first. And if it's a good match treat the patch before installing it.
Then another idea more in the line of cosmetics. Recreate the stitch between the top piece of the seat and the side piece in your patch. It will look less out of place.
Add about a half inch to the top and bottom of the patch material. Invert the patch and place it across the seat on the other side of the vehicle and trace the line of the seam. This should closely approximate the curve on the torn side.
Cut the patch on this line. Place the left half on top of the right half as if you were folding the piece in half. The curve of the cut should match. Sew about one half inch in from the cut sewing the two pieces together. Open the piece up like a butter fly and you may wish to iron the piece open at this point. Sew a hem around the piece as shown in the instructable. Match up the patch with the seem and sew the patch over the torn area following the instructable.
Great idea wished I had thought of doing that in some of my vehicles.
Zibodiz (author) in reply to pbates123Sep 9, 2012. 12:07 PM
That's some great advice. The dye was an afterthought -- if I had thought of it in advance, I would have definitely tried it first, and would highly recommend that others do. Since it's been a few days, the dye has faded a little now, and actually matches very well; so in the end I'm pretty happy with how it turned out.
As far as making an unneeded seam to imitate the seam that would have been there, that's a brilliant idea, and I just wish I had thought of it :-)
dreiseratops says: Sep 2, 2012. 12:15 AM
Maybe a little too much but it sure looks better than blue. ;)
Hell blue looks a heck of a lot better than yellow...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
