loading
Step 1: Materials en tools
What do you need to make the pattern maker?
    1. Materials:
  • Plywood 5mm (3 x 600mmx600mm)
  • Plexiglas 3 - 4mm (1x 150mmx150mm)
  • Small wood screws
  • 1 bolt and 1 nut M6
  • Handles
  • Wood Glue
  • Small magnets
  • Glue
  • 2 small hinges
  • Sandpaper
  • 4 lego wheels with corresponding wheel axle
  • Brick timber in which the head of the dremel passes
    2. Equipment / Tools:
  • Laser Cutter
  • 3D printer
  • Dremel + flexible hose extension and ceramic grinding head
  • Drill + clock drilling
looking interesting
what is you cnc laser machine ?
<p>I need to ckeck it in school</p>
What other patterns can be done with this?
You have a pattern to make 3 lines on the glass. Another with 2 lines ans the last is also with 3 lines but the distances of the lines are different.
<p>You can see the 3 patterns on the photo</p>
<p>?? what ???</p>
<p>mmm how to say that... good work! but all theses efforts just for 3 lines on a glass (limited to a specific size, impossible to use it with a larger or other shape ?) Is this pattern has a particular meaning ?</p>
<p>The pattern maker can use more glasses</p>
About This Instructable
2,782views
19favorites
License:
More by Jay Bytebier:Pattern maker glass Storage Box Buzz fire
Add instructable to:
