loading
Step 6: Pattern Maker Part 2
  • Step 4
First take a wooden cube of 25 mm at 25 with a minimum height of 20 mm.
Now drill with a drill bit a hole in the wooden piece for the hose from the dremel. The diameter must be 11 mm. Drill then on 1 side of the cube a hole for the nut and the bolt with diameter 6 mm. Do it booth in the middle of the block. You need to place the nut in the hole with some glue. (4)
If this cube is ready, you need to place the hole of 11 mm concentric with the hole on the upper plate.
looking interesting
what is you cnc laser machine ?
<p>I need to ckeck it in school</p>
What other patterns can be done with this?
You have a pattern to make 3 lines on the glass. Another with 2 lines ans the last is also with 3 lines but the distances of the lines are different.
<p>You can see the 3 patterns on the photo</p>
<p>?? what ???</p>
<p>mmm how to say that... good work! but all theses efforts just for 3 lines on a glass (limited to a specific size, impossible to use it with a larger or other shape ?) Is this pattern has a particular meaning ?</p>
<p>The pattern maker can use more glasses</p>
About This Instructable
3,904views
21favorites
License:
More by Jay Bytebier:Pattern maker glass Storage Box Buzz fire
Add instructable to:
