Introduction: Pax Vaporizer Battery Replacement
Picture of Pax Vaporizer Battery Replacement
Replacing old battery with a high capacity Panasonic NCR18650B in Pax Vaporizer.
Tools needed:
  • T4 Torx driver
  • Knife
  • Soldering iron
Materials needed:
  • Solder
  • Shrink tubing
  • Electrical tape
  • Replacement 18650 Lithium Ion battery with pre-welded tabs
Pre-tabbed NCR18650B are available here (xpresstekstore.com)
Step 1: Disassembly
Picture of Disassembly
Remove a single T4 Torx screw from the back of the unit.
Step 2: Disassembly, Cont.
Picture of Disassembly, Cont.
Slide the cover toward the mouthpiece. The cover is very tight and may require some force to slip off the unit. Be careful not to loose 2 little bowl magnets as shown in the image.
Step 3: Disassembly, Cont.
Once the cover is off, you will see the internal circuitry and a single battery cell taped to the unit.
Step 4: Battery Removal
Picture of Battery Removal
Carefully cut the tape, remove it from the battery and slide the battery out of its compartment.
Step 5: Disconnecting Battery
Picture of Disconnecting Battery
Simply rip the weld tabs off the battery.
Step 6: Insulation Removal
Picture of Insulation Removal
Using a knife, cut and remove the shrink tube insulation from the weld tabs and wires. After shrink tubing is off, the solder joints will be visible. Use a soldering iron to desolder tabs from the wires.
Step 7: Prepare the Wires
Picture of Prepare the Wires
Slip new shrink tubing over the wires. You can also use electrical tape in the later steps if you don't have shrink tubing.
Step 8: Connect New Battery
Picture of Connect New Battery
For a replacement, I used Panasonic NCR18650B 3400 mAh battery. This cell had the solder tabs spot welded on in our shop. The tabs are thinner and narrower than standard weld tabs in order to match the original.
Solder the wires to the terminal tabs only.
Do not solder directly to the battery!!!
Step 9: Complete the Insulation
Picture of Complete the Insulation
Slide the shrink tubing over the terminal tabs and solder joints leaving as little of the tabs exposed, as possible. Heat them up with a hair dryer or a heat gun to shrink in place.
Step 10: Re-assembly
Picture of Re-assembly
Insert the battery back into its compartment and replace the tape that was cut during the disassembly, any electrical tape will do. Slide the cover back over the unit, replace the torx screw.
Your Pax will not turn on. Don't worry, you just need to "unlock" the internal protection circuit. Simple place your Pax on its charging base and make sure that it is plugged in. Watch that light come to life!
DannyR77 (author)2017-07-30
Thanks! Two successes with this guide. Make sure to orient the battery right! Haha
ReubenA8 (author)2017-03-25
I've done the replacement but the pax doesn't turn on even after charging.
Diescum88 (author)2017-02-12
is there a way to bypass having to use the charger? have a pax 2 clone that won't charge and was gonna try replacing battery making it interchangeable
drem reeds (author)2015-12-06
was there any improvement to quality or battery life?
poctob (author)drem reeds2015-12-07
Yes, about 30%.
PjD12 (author)poctob2017-01-12
Any Idea as to where to get the pretabbed battery you used here? The link you gave is out of stock and my pax lasts for one maybee two heat ups:(
poctob (author)PjD122017-01-13
Search ebay for NCR18650B with tabs. Last I checked, couple sellers in the US have them.
