Peacock Costume
17,376
77
Published
Introduction: Peacock Costume
Hi everyone! This was my costume last year. I got tons of complements and many people asked how I made it. Here is what I did…
Step 1: Step 1
Take a strip of elastic with sequins on it and a blue feather boa. Cut the elastic band so it will comfortably fit around your waist and secure it with a safety pin. Next, pin one end of the boa to the sequin strip and loop it up and down, attaching the boa to the elastic band with small safety pins. See photo below for better understanding:
Step 2: Step 2
Find a tight fitting tank you don't mind changing up. Add the same color elastic sequins wherever you would like on the tank using hot glue gun. I chose to put it down the center because everywhere else what just a mesh material. Add feathers to the cups of the top. Use any colors you want to match your peacock feathers. Attach feather and sequins using hot glue.
Step 3: Step 3
Using a handheld fan or a mask, attach a variety of lengths of peacock feather so that they are spread out. I found my feathers at an online hobby store and used about 75 I believe. Arrange the feathers so that they fan out and look full. I used the hot glue to attach everything. It won't be extremely sturdy just yet so be careful holding it up
Step 4: Finalize
Add some fun make-up or face paint to tie the whole look together. Put the skirt on with hot pants (or biker shorts) under, then the top. I wore bright yellow/green tights to add to the look as well. Tie the base of you feathers around your waist and hide the tie under your top and the waistband of your skirt. Then, loop two strings through the feathers and tie them to your straps for added support so they don't fall backwards. You can't ride in the car like this, so do this right before you enter the party. The fan of feathers should be really easy to take off and on if you do this without making any knots.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    3 Comments
    but.... those feathers are male peacock feathers... lol... just saying.
    Thanks for posting! I love how creative yet simple this is! I look forward to more projects :)
    - Michelle
