Pearl Jewelry Design - How to Make a Handmade Three-Strand White Pearl Bead Necklace
508
10
Posted in CraftJewelry
Introduction: Pearl Jewelry Design - How to Make a Handmade Three-Strand White Pearl Bead Necklace
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Looking for DIY pearl necklace designs? What about the following three-strand white pearl bead necklace? Follow me to see how it's made if you like it.
Step 1: Supplies Needed in DIY the Three-strand White Pearl Bead Necklace:
8mm White Round Pearl Beads
6mm White Round Pearl Beads
Golden 6-Hole Magnetic Slide Lock Clasps
Rhinestone Bridge Spacers
0.2mm White Fishing Wire
Stainless-Steel Scissor
Step 2: Make the First Part of the Three-strand White Pearl Bead Necklace
1st, cut about 270cm 0.2mm white fishing wire. Then, cross the wire through one hole of a golden 6-hole magnetic slide lock clasp and make some knots (as shown in the picture);
2nd, add about 34 6mm white round pearl beads to the wire (as shown in the picture);
3rd, add a rhinestone bridge spacer (as shown in the picture);
4th, add an 8mm white round pearl bead and a rhinestone bridge spacer (as shown in the picture);
Step 3:
5th, add about 34 6mm white round pearl beads to the wire (as shown in the picture).
Step 4: Make the Rest Part of the Three-strand White Pearl Bead Necklace
1st, move the wire to the second hole of the golden magnetic slide lock clasp and make some knots. Then, add about 36 6mm white round pearl beads to the wire. Then, cross the wire through the middle hole of the rhinestone bridge spacer. Then, add an 8mm white pearl bead, a 6mm white pearl bead and an 8mm white pearl bead (as shown in the picture);
2nd, cross the wire through the middle hole of the other rhinestone bridge spacer. Then, add about 36 6mm white round pearl beads to the wire and make some knots around the second hole of the other part of the golden magnetic slide lock clasp (as shown in the picture);
3rd, move the wire to the external hole of the golden magnetic slide lock clasp and make some knots. Then, add about 40 6mm white round pearl beads to the wire. Cross the wire through the external hole of the rhinestone bridge spacer. Then, add an 8mm white pearl bead, a 6mm white pearl bead, an 8mm white pearl bead, a 6mm white pearl bead and an 8mm white pearl bead (as shown in the picture);
4th, cross the wire through the external hole of the other rhinestone bridge spacer. Then, add about 40 6mm white round pearl beads to the wire and make some knots around the rest hole of the other part of the golden magnetic slide lock clasp (as shown in the picture).
Step 5: Here Is the Final Look of the Three-strand White Pearl Bead Necklace.
You can wear this three-strand white pearl bead necklace to match your black dress or other closes. There are no professional techniques in this DIY project. If you like this three-strand white pearl bead necklace, just give it a try!
    • Flowers Challenge
      Flowers Challenge
    • Spotless Contest
      Spotless Contest
    • Slow Cooker Challenge
    Can you please expand on the types of knots you are tying? And thank you for the Instuctable!
