Pearl Jewelry Design - How to Make a Handmade White Pearl Bead Statement Necklace
15,429
75
7
Published
Introduction: Pearl Jewelry Design - How to Make a Handmade White Pearl Bead Statement Necklace
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Looking for pearl necklace patterns? What about this white pearl bead statement necklace? Just read on the detailed instructions below to see how to make this white pearl statement necklace.
Step 1: ​Supplies Needed in Making the White Pearl Bead Statement Necklace:
8mm White Round Pearl Beads
2mm White Round Seed Beads
0.2mm White Fishing Wire
Silver Ring End Clasps
Silver Jump Rings
Stainless-Steel Scissor
Needle
Step 2: Make the First Part of the White Pearl Bead Statement Necklace
1st, cut a piece of 0.2mm fishing wire and add a silver ring end clasp to the middle of it. Then, thread 3 2mm white round seed beads to the left wire and 7 2mm white round seed beads to the right wire;
2nd, cross the let wire through the right four white seed beads on the right wire and tighten (as shown in the picture);
3rd, thread about 9 2mm white seed beads, an 8mm white round pearl bead, 4 2mm white seed beads and an 8mm white round pearl bead in sequence to the right wire (as shown in the picture);
4th, cross the right wire through the 5th seed bead of the 9 seed beads. Then, cross the right wire through the 4 adjacent seed beads and the 4 seed beads of the 1st loop (as shown in the picture);
5th, thread about 7 white seed beads to the right wire;
6th, cross the right wire through the 4th seed bead of the adjacent hoop (as shown in the picture).
Step 3: Make the Second Part of the White Pearl Bead Statement Necklace
1st, thread an 8mm white pearl bead and 4 white seed beads to the right wire;
2nd, cross the wire through the 1st seed bead of the two-pearl hoop pattern (as shown in the picture);
3rd, thread an 8mm white pearl bead, 4 white seed beads and an 8mm white pearl bead in sequence to the right wire;
4th, cross the wire through the 1st seed bead beside the top white pearl bead (as shown in the picture);
5th, thread 4 white seed beads and an 8mm white pearl bead to the right wire.
Step 4: Make the Third Part of the White Pearl Bead Statement Necklace
1st, cross the right wire through the 4th seed bead beside the top white pearl bead (as shown in the picture);
2nd, thread about 7 white seed beads to the right wire. Then, cross the right wire through the adjacent two seed beads. Thread an 8mm white pearl bead and 4 white seed beads to the right wire (as shown in the picture);
3rd, cross the right wire through the top seed bead of the two-pearl bead pattern. Then, thread an 8mm white pearl bead, 4 white seed beads and an 8mm white pearl bead to the right wire (as shown in the picture);
4th, cross the right wire through the top seed bead of the three-pearl bead pattern. Then, thread 4 white seed beads and an 8mm white pearl bead in sequence (as shown in the picture);
5th, cross the right wire through the 3rd seed bead beside the top white pearl bead in the second row. Then, thread about 7 white seed beads (as shown in the picture);
6th, cross the right wire through the two seed beads (as shown in the picture);
Step 5: 7th, Refer to the Above Steps to Make More Such Bead Patterns (as Shown in the Picture).
Step 6: Make the Rest Part of the White Pearl Bead Statement Necklace
1st, cross the wire through the two seed beads (as shown in the picture);
2nd, cross the wire through the adjacent three seed beads. Then, thread about 7 white seed beads and cross the wire through the seed beads (as shown in the picture);
3rd, refer to the above steps to make a triangle seed bead pattern on the right side. Then, connect the two ends of the white pearl bead statement necklace through a silver jump ring (as shown in the picture).
Step 7: Here Is the Final Look of the White Pearl Bead Statement Necklace.
This white pearl bead statement necklace can add elegance to your beauty when you wear it around your neck. The beading techniques used in this DIY project may be a little complex. So, be patient during the beading process. Have a nice try!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    7 Comments
    Thanks so much:)
    This is a great instructable. I have only one question. How long is the piece of fishing wire i need?
    Hi, it needs about 10 meters. You can add the length if it is not enough and do it according to your neck.
