3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pectin from Scratch
Pectin from Scratch
Pectin causes jams and jellies to gel. When using a pectin poor fruit, pectin must be added or the result will be nothing more than a fruit syrup. I refuse to use store bought pectin because I think it takes the craft out of jam and jelly making. Usually I just add apple skins and cores to whatever I'm making, but I thought I'd give making my own pectin a try.
The basic method is to take a pectin rich fruit and extract the water soluble pectin by boiling it, then concentrating the liquid. Apples are a good source of pectin because they both contain a lot of pectin and have a relatively neutral flavour (as opposed to orange peels for instance).
Step 1Ingredients and tools
Pectin is concentrated in the cores and skins of all apples, and is especially strong in tart green apples. Using the cores and skins left over from making a pie is a great way to upcycle your scraps. For this instructable I used crabapples that didn't have enough flavour to bother with crabapple jelly.
Ingredients:
3 lb Apples
4 cups Water
2 Tbsp Lemon Juice
Unusual Tools:
Jelly bag/cheese cloth and strainer
I am using the basic method from www.pickyourown.org, a website with a lot of very helpful information.
20 comments
Jul 29, 2011. 9:57 PMsusanrm says:
This looks interesting, but I wonder if it would cause problems with my apple allergy. Any ideas?
Sep 3, 2011. 10:13 AMbettyroug54 says:
If you are allergic to apples my guess, would be that you have a Salicylate allergy. Can you take aspirin without any problem? If not, that would confirm your allergy. In this case you would not want to use apple pectin.
There is a pectin on the market that is totally organic in nature, made from citrus fruit (you can call them and see if there are any salicylates in the product)can be used with any type of sweetener (it does not require sugar to cause the jelling - it uses calcium) so you can use as little as 1/2 cup of any type of regular sweetener per batch like, agave, honey cane sugar, stevia, etc. It is called "Pamona's Universal Pectin" and is absolutely wonderful! It can be purchased in health food stores or you can buy online in bulk which is what I do. No more 7 cups of sugar to make the jelling take place, you don't even really have to use sweetener if the fruit is sweet enough for your taste, and you can make multiple batches all at once saving you lots of time. Comes out with a perfect jell every time. Give it a try. Here is the link http://www.pomonapectin.com/. You will probably have to copy and paste to your address bar.
Sep 3, 2011. 7:22 PMsusanrm says:
Hi Betty,
It's been years since I've had aspirin, but my allergy is actually OAS - oral allergy syndrome. It's a crossover from tree pollen allergies (extreme in NY this spring), where suddenly I would have a bad reaction when eating fresh apples, peaches, pears, mulberries, cherries, dates - a whole bunch of tree fruits, but not all. The pectin sounds really nice, but I did buy some sugar-free pectin from Bell that sounds very similar to what you describe.
Sep 3, 2011. 9:16 PMbettyroug54 says:
Hi Susan:
Glad you were able to find a pectin you can use. I was reading an article about OAS on WebMD. Sound like you really need to be careful during pollen season. Best of luck to you!
Jul 30, 2011. 9:57 AMCarbonfree Jenny says:
Amazing guide! I can't wait to try this in the fall with the farmer's markets apple seconds. Seems like as long a you remove the nasty bits it would be fine.
Thanks so much!
May 23, 2011. 9:46 AMbowow0807 says:
hey can i use slightly overripe or slightly off apples? because we have here a lot of fruit venders here and im wondering if i can use the apples normally thrown away.
Feb 11, 2010. 3:07 PMb1russell says:
Thank you!  No more commercial (as in, don't know exactly what's in it!) pectin for me!  I have to try this.  P.S. Know any great recipes for grapefruit?  The tree is groaning!
Dec 11, 2009. 3:30 AMchiok says:
I'm currently running through the same process for making chilli jelly, by using bramley apples boiled and strained and mixed with sugar and chilli.
For those that don't have a cheesecloth or jelly bag, I use two blue dishclothes, the thin type similar to a hospital examination gown or that napkin you get at the dentist.  Two clothes dunked in boiling water to sterilise, then lay one over the other in cross, line a pan with it, pour in the apples, then gather up the ends of the cloth and tie with string.  Then I lay a broomstick across two chairs, put a bowl between the chairs and tie the bag to the broom.
Dish clothes aren't as sturdy as a cheesecloth, but more readily available and do a similar job.
Oct 26, 2009. 6:52 AMshmacky26 says:
 Great instructable, but two questions, 1, for crab apples, should I peel and core them, and just cook the peels and the cores, or is the whole apple cut up ok?  Also, will my jams and jellies taste like crabapple?
Thanks!
Nov 3, 2009. 8:18 AMshmacky26 says:
 Great stuff, thanks.  I have under an acre of land and try to use it as much as I can, I was going to cut down the crab apple trees as I only use them for compost, but now I think I'll keep them.
Oct 26, 2009. 7:32 AMbero2 says:
Hey, really nice guide! I bet it will help a lot more than just adding a bit of lemon or orange juice to my jams.
Could you clarify this line for me? I can't get what you're trying to say.
"a few minutes of boiling will concentrate bother the pectin, and the flavour and may push it over the edge to gelling. "
Oct 26, 2009. 6:53 AMandycyca says:
Marvelous! Time for scavenging those jam recipes!
Oct 26, 2009. 5:03 AMrimar2000 says:
THANKS! I didn't know this could be done at home.
Oct 25, 2009. 9:46 PMWeissensteinburg says:
This is a great instructable! I love making things for scratch that we normally take for granted.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:NoFiller
