Pedometer
7,772
76
10
Published
Introduction: Pedometer
About: hello, i'm a student of electronic and communication. i love making things which are easy to build, cheaper and create a deep impression on others.
Hello guys, This is my second electronic project .Please share and vote if you like.
What is PEDOMETER?
Answer- A pedometer is a device, usually portable and electronic or electromechanical, that counts each step a person takes by detecting themotion of the person's hands or hips. Because the distance of each person's step varies, an informal calibration, performed by the user, is required if presentation of the distance covered in a unit of length (such as in kilometres or miles) is desired.
Presented here is a simple pedometer circuit. It measures the distance covered by you while walking. It may not work very well for running!
Step 1: Item Required.
  1. CD4093 quad 2-input NAND schmitt trigger X 1
  2. CD4024 counter/divider x 1
  3. CD4026 decade counter/divider x 2
  4. BC327 pnp transistor x 2
  5. 22k Resistor x 2
  6. 2.2 m Resistor x 1
  7. 4.7 k Resistor x 3
  8. 47 ohm Resistor x 1
  9. 1k Resistor x 2
  10. 47nf ceramic disk capacitor x 1
  11. 330nf tantalum capacitor x 1
  12. 10nf ceramic disk capacitor x 1
  13. LTS543, 7 - segment display x 2
  14. Tilt/ mercury switch
  15. on/off switch x 2
  16. Tactile switch x 2
  17. 2 pin terminal block
  18. 3v battery. ( i use 9 v battery with proper resistor, you only use 3v)
  19. An empty plastic box
Step 2: Construction.
  1. Take a vero board, and first assemble 4093 IC and then other IC according to systematic.
  2. if you want to make a printed circuit board. i also upload actual size pcb design and component layout.
  3. add tilt sensor .
  4. add resistors
  5. add capacitor.
  6. now add 7-segment display.
  7. do not attach (reset) and ( display) switch on board, because it attached on plastic box. these switch install later.
  8. solder components, according to given systematic.
  9. cut the board according to size of box.
  10. take box and cut two windows for displays
  11. also make 4 holes for switches (reset) and for (display)
  12. install the circuit board into the box , carefully.
  13. add on/off button on the side of plastic box.
  14. add chart paper and name marking.
i did not add any buzzer, because i don't need it. ( if you want to add , install buzzer with 47 ohm resistor)
The circuit is built around quad 2-input Schmitt trigger CD4093 (IC1), CMOS ripple carry binary counter/divider CD4024 (IC2), decade counter/divider CD4026 (IC3 and IC4), two transistors BC327 (T1, T2) and some other components.
Gates N1 and N2 of IC1 form a monostable multivibrator that receives trigger input from tilt or mercury switch S1. When you lift your foot up and touch the ground back during walking, the mercury inside the switch makes a contact with its two metallic leads. This makes the current to flow between the metallic leads and a pulse is generated at pin 4 of IC1.
This pulse is fed to pin 1 of IC2 that produces a divide-by-64 counter. Its output is given to inputs of gate N4 of IC1 and the output of N4 is fed to the base of transistor T2 through resistor R8. Transistor T2 drives the decimal point segment of common cathode 7-segment display (DIS1)
IC3 and IC4 are configured as decade counters to drive the 7-segment displays DIS1 and DIS2, respectively.
Step 3: Working.
How it works .
Switch S4 resets these two counters and switch S5 enables DIS1 and DIS2 displays.
Transistor T1 drives the piezobuzzer (PZ1), which beeps after every two steps (one stride), provided switch S2 is closed. DIS1 and DIS2 displays indicate the distance covered in metre (m) and kilometre (km) units, respectively.
Generally, walking step of each individual is slightly different. Here, we assume that a single step is 78cm long, which is the average. According to this, 64 strides equal 100m (that is, 2×0.78×64=99.84m or 100m (approx.)) or 128 steps equal 100m.
DIS1 increments the digit after every 100m distance. That is, DIS1 displays 1 when distance covered is 100m and 2 when distance covered is 200m, and so on. After digit 9 in DIS1, DIS2 increments from 0 to 1 digit. The decimal point (dot) of DIS2 always glows to indicate separation of kilometre from the metre unit.To save battery power consumption, DIS1 and DIS2 displays illuminate only when you push S5. If you want to reset the counter circuit, both switches S4 and S5 must be pressed simultaneously.
If you want to continuously illuminate DIS1 and DIS2 displays, remove switch S5 and connect the junction of S4 and emitter of transistor T2 to 3V.
use 3vbattery (not use 9v) ......... take two AA size batteries , connect them in series and use.
Step 4: Done.
Enjoy this built and keep walking.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx THANK YOU XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Feet Challenge
Runner Up in the
Feet Challenge
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    10 Discussions
    I was expecting something different with the name pedometer.
    I think you should rewrite this and either show how you used a 9 volt battery, or remove where you talked about using a 9 volt battery. It wouldn't be hard since you didn't take any pictures of your completed project showing the 9 volt battery. I also feel this project should have switchable distance units. I know most parts of the world use the metric system, most, not all That's just my opinion. Otherwise, this seems to be a very helpful and well built project. Keep up the good work!
    Thank you for comment. :-)
    This whole circuit works on 19 ma current rating, which is the operating current of a 3mm LED.
    3 V battery gives 20-25 ma current
    so
    V=IR
    9=I X 500
    I = 0.018 a
    Here i used 9v battery with 500 ohm resistor. i also placed a led to check how resistor works because led is also operate at 18ma current.
    this project does not having any switchable distance units. When the mercury switch is closed or open 128-130 times, it shoes 1 reading.
    I will definately upgrade this project and some more pictures.
    i hope this will clear you doubts. Thanks for this comment, this help others.
    Thanks:-) Build your own, and check it out
    Thanks for your comment. this project is very easy to do, take care about soldering. (i faced many problems)
